How to use LDCAD on Linux (Nixos)?
Hello, I want to use LDCAD on Linux. I tried to run it using Wine, but it doesn’t work. I loaded the libraries and everything. Then I loaded it up and got to the welcome screen and this is what it looks like, and it then crashes with an error after I create a new project.
I then tried to run the native linux version and I get the following errors
Copying executable to: /usr/bin
‘LDCad64’ → ‘/usr/bin/LDCad’
Copying data files to: /usr/share/LDCad
‘seeds/colorBin.sf’ → ‘/usr/share/LDCad/seeds/colorBin.sf’
‘seeds/donors.sf’ → ‘/usr/share/LDCad/seeds/donors.sf’
‘seeds/examples.sf’ → ‘/usr/share/LDCad/seeds/examples.sf’
‘seeds/glTF.sf’ → ‘/usr/share/LDCad/seeds/glTF.sf’
‘seeds/gui.sf’ → ‘/usr/share/LDCad/seeds/gui.sf’
‘seeds/partBin.sf’ → ‘/usr/share/LDCad/seeds/partBin.sf’
‘seeds/povray.sf’ → ‘/usr/share/LDCad/seeds/povray.sf’
‘seeds/scripts.sf’ → ‘/usr/share/LDCad/seeds/scripts.sf’
‘seeds/shadow.sf’ → ‘/usr/share/LDCad/seeds/shadow.sf’
‘seeds/templates.sf’ → ‘/usr/share/LDCad/seeds/templates.sf’
‘docs/changeLog.txt’ → ‘/usr/share/LDCad/docs/changeLog.txt’
‘docs/manual.txt’ → ‘/usr/share/LDCad/docs/manual.txt’
‘resources/conLine_geoMethod.gsl’ → ‘/usr/share/LDCad/resources/conLine_geoMethod.gsl’
‘resources/LDCad-128x128.png’ → ‘/usr/share/LDCad/resources/LDCad-128x128.png’
‘resources/LDCad.ico’ → ‘/usr/share/LDCad/resources/LDCad.ico’
‘resources/conLine_geoMethod.vsl’ → ‘/usr/share/LDCad/resources/conLine_geoMethod.vsl’
‘resources/conLine_verMethod.vsl’ → ‘/usr/share/LDCad/resources/conLine_verMethod.vsl’
Creating config file: /etc/LDCad.cfg
Creating ldraw mime type file: /usr/share/mime/packages/ldraw.xml
./setup.sh: line 103: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 104: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 105: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 106: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 107: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 108: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 109: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 110: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 111: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 112: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 113: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 114: /usr/share/mime/packages/ldraw.xml: No such file or directory
./setup.sh: line 115: /usr/share/mime/packages/ldraw.xml: No such file or directory
Updating mime database.
Directory ‘/usr/share/mime/packages’ does not exist!
./setup.sh: line 123: ./genDskEntry.sh: Permission denied
Updating desktop database.
./setup.sh: line 128: update-desktop-database: command not found
All done.
