How to Wirelessly Download Programs to the V5 Brain
Hey Guys,
I’m new to V5 this year and I was wondering if there was a way to download code wirelessly to the brain (i.e through the controller with the programming hardware kit from legacy”
Thanks
Ani
use vexcode and you can download programs on your controller. It has to be connected to the brain. Use the charging cable of the controller to connect it with your computer.
If you are using PROS the same applies. Plug into the controller on USB and hit the upload command.
With PROS I recommend using the hot/cold linking they released with the wireless upload update. It will speed up your upload times quite a bit. Here’s where you can find out how to set that up:
https://pros.cs.purdue.edu/v5/tutorials/topical/wireless-upload.html
Is that something you can also do with Pros?
Yes. There isn’t much you can’t do with PROS.
