How to write PID code
So I’m working on PID and I have all the functions down, but I’m trying to figure out how to make the code run. Here is a sample of my code
void autonomous(void) {
//turn on the PID
vex::task WhateverSomethingRandom(driverPID);
//move the back lift down and then back up
HeroLift.spin(forward, 100, pct);
wait(1.2, seconds);
HeroLift.stop(coast);
HeroLift.spin(reverse, 100, pct);
wait(1.1, seconds);
HeroLift.stop(hold);
vex::task::sleep(200);
//turn to the right
resetDriveSensors = true;
DesiredTurnValue = 180;
//move forward 36 inches
DesiredValue = 2057;
I’m just checking to see if this is how I make my motors actually turn the way I want them too or if I have to write it in a different way. If you can help please just respond to this. (All of these values are in degrees)
Please use code tags.
Put ```, and on the next lines, your code, and after the last line of code, three more back ticks. (They’re above the tab key.)
I would not suggest this. I would suggest
void turn(double angle) {
  DesiredTurnValue += angle;
  for (int i = 0; i < 10; i++) {
    waitUntil(/*gyro reading or whatever is within acceptable error margin*/)
That way your waits are exactly the length they have to be. I guess some people do it the way you are, though, so I suppose it works. Take your pick.
