I know there are instructions in the template itself, but I think I am interpreting them in a different fashion. Could anyone instruct me on how to input my user control code into the competition template? Both my code and competition template are attached below.
#include "robot-config.h"
int Catapult = 0;
bool Intake = 0;
int Lift = 0;
bool StoppingType = 0;
bool DriveSpd = 0;
// Switch //
void ChangeIntake()
if(Catapult == 1)
::Intake = !Intake;
void SwitchFunction()
while(true)
Brain.Screen.clearScreen();
Brain.Screen.setCursor(1,1);
Brain.Screen.print(Intake);
if(Catapult == 0)
Intake = 0;
LSwitch.stop();
RSwitch.stop();
else if(Catapult == 1)
if(Lever.pressing())
Controller1.ButtonL1.pressed(ChangeIntake);
if(Intake == 0)
LSwitch.stop();
RSwitch.stop();
else if(Intake == 1)
LSwitch.spin(vex::directionType::fwd,100,vex::velocityUnits::pct);
RSwitch.spin(vex::directionType::fwd,100,vex::velocityUnits::pct);
else
Intake = 0;
LSwitch.spin(vex::directionType::rev,100,vex::velocityUnits::pct);
RSwitch.spin(vex::directionType::rev,100,vex::velocityUnits::pct);
else if(Catapult == 2)
vex::task::sleep(300);
Catapult = 0;
void ChangeCatapult()
if(Catapult == 2)
Catapult = 1;
else
Catapult++;
// DRIVE //
void SwitchDrive()
::DriveSpd = !DriveSpd;
void SwitchStopping()
::StoppingType = !StoppingType;
void BrakeFunction()
while(true)
if(StoppingType == 0)
Controller1.Screen.clearLine();
Controller1.Screen.print("Unlocked");
LMotor1.setStopping(vex::brakeType::brake);
LMotor2.setStopping(vex::brakeType::brake);
RMotor1.setStopping(vex::brakeType::brake);
RMotor2.setStopping(vex::brakeType::brake);
else if(StoppingType == 1)
Controller1.Screen.print("Locked");
LMotor1.setStopping(vex::brakeType::hold);
LMotor2.setStopping(vex::brakeType::hold);
RMotor1.setStopping(vex::brakeType::hold);
RMotor2.setStopping(vex::brakeType::hold);
void DriveFunction()
while(true)
if(DriveSpd == 0)
LMotor1.spin(vex::directionType::fwd, Controller1.Axis3.value(), vex::velocityUnits::pct);
LMotor2.spin(vex::directionType::fwd, Controller1.Axis3.value(), vex::velocityUnits::pct);
RMotor1.spin(vex::directionType::fwd, Controller1.Axis2.value(), vex::velocityUnits::pct);
RMotor2.spin(vex::directionType::fwd, Controller1.Axis2.value(), vex::velocityUnits::pct);
else if(DriveSpd == 1)
LMotor1.spin(vex::directionType::fwd, Controller1.Axis3.value()/3, vex::velocityUnits::pct);
LMotor2.spin(vex::directionType::fwd, Controller1.Axis3.value()/3, vex::velocityUnits::pct);
RMotor1.spin(vex::directionType::fwd, Controller1.Axis2.value()/3, vex::velocityUnits::pct);
RMotor2.spin(vex::directionType::fwd, Controller1.Axis2.value()/3, vex::velocityUnits::pct);
// Lift / Cap //
void LiftFunction()
while(true)
LiftMotor.spin(vex::directionType::fwd,Controller2.Axis2.value(),vex::velocityUnits::pct);
void CapFunction()
while(true)
CapMotor.spin(vex::directionType::fwd,Controller2.Axis4.value()/2,vex::velocityUnits::pct);
// Main Task //
int main()
CapMotor.resetRotation();
LiftMotor.resetRotation();
RMotor1.setReversed(true);
RMotor2.setReversed(true);
LiftMotor.setReversed(true);
LSwitch.setReversed(true);
LSwitch.setStopping(vex::brakeType::coast);
RSwitch.setStopping(vex::brakeType::coast);
LiftMotor.setStopping(vex::brakeType::hold);
CapMotor.setStopping(vex::brakeType::hold);
Controller1.ButtonY.pressed(SwitchStopping);
Controller1.ButtonB.pressed(SwitchDrive);
Controller2.ButtonR1.pressed(ChangeCatapult);
vex::thread drivethread (DriveFunction);
drivethread.detach();
vex::thread brakethread (BrakeFunction);
vex::thread liftthread (LiftFunction);
liftthread.detach();
vex::thread capthread (CapFunction);
capthread.detach();
vex::thread switchthread (SwitchFunction);
switchthread.detach();
/* Description: Competition template for VCS VEX V5 */
//Creates a competition object that allows access to Competition methods.
vex::competition Competition;
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the cortex has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton( void ) {
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void autonomous( void ) {
// Insert autonomous user code here.
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol( void ) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
vex::task::sleep(20); //Sleep the task for a short amount of time to prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
//Run the pre-autonomous function.
pre_auton();
//Set up callbacks for autonomous and driver control periods.
Competition.autonomous( autonomous );
Competition.drivercontrol( usercontrol );
//Prevent main from exiting with an infinite loop.
while(1) {
vex::task::sleep(100);//Sleep the task for a short amount of time to prevent wasted resources.
