I’m new to onshape and I’m not sure how to add polycarb using it into my design. I heard about the part studio, but I don’t know how to use it to make polycarb.
Assuming your robot is in assembly
- Create part studio in context
- Select origin
- Create sketch and make your polycarbonate
- Insert and go to assembly
- If it doesn’t show up then press insert then current assembly and insert it from there
I created configurable polycarbonate, options are 1/16 inch and 1/32 inch. There is one with only one hole on each side and two holes of each side. My Onshape username is Koko2008zzzz I have them set to public
I tried searching by user but I can’t. Could you send a link to the onshape document?
Double Hole
Single Hole
High Strength Axle with holes on ends
