HS 84 tooth gear CAD
I am looking for a High Strength 84 tooth gear with a square insert that I can use on Autodesk Inventor. Unfortunately, it appears as though this isn’t available from the VEX Robotics webpage. Does anyone have a file for this?
On this page: Gears - VEX Robotics
at the bottom is a tab “docs and downloads” where you can find the .stp files for all parts. Import the .stp file into your CAD software.
You can only download the gear set
The STEP file for the 84 tooth gear is in that ZIP. You can download it here: https://content.vexrobotics.com/cad/STEP/HS-Gears-121216-STEP.zip
Thanks. That helps a lot.
Are the square inserts included in the file?
Indeed they are.
