I can't quite figure out why my code is not working
I am a new user on VEX Forums and I am facing issues with my current code for competition template. The autonomous and driver control functions do not work when running the code and changes made to the motor’s direction (false/true parameter in the motor() function do not change the direction of the bot. Is there a reason as to why this is happening? Help is greatly appreciated.
main.cpp:
type or paste code here
/*    Module:       main.cpp                                                  */
/*    Author:       VEX                                                       */
/*    Created:      Thu Sep 26 2019                                           */
/*    Description:  Competition Template                                      */
#include "vex.h"
using namespace vex;
competition Competition;
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the V5 has been powered on and        */
/*  not every time that the robot is disabled.                               */
//VEXcode Device constructors
controller Controller1 = controller(primary);
motor leftMotorA = motor(PORT6, ratio6_1, false);
motor leftMotorB = motor(PORT10, ratio6_1, false);
// above is the lone topmost motor
motor leftMotorC = motor(PORT8, ratio6_1, true);
motor_group LeftDriveSmart = motor_group(leftMotorA, leftMotorB, leftMotorC);
motor rightMotorA = motor(PORT5, ratio6_1, false);
motor rightMotorB = motor(PORT2, ratio6_1, true);
motor rightMotorC = motor(PORT3, ratio6_1, true);
motor_group RightDriveSmart = motor_group(rightMotorA, rightMotorB,  rightMotorC);
drivetrain Drivetrain = drivetrain(LeftDriveSmart, RightDriveSmart, 319.19, 295, 40, mm, 1);
motor Intake1 = motor(PORT15, ratio6_1, false);
motor Intake2 = motor(PORT14, ratio6_1, false);
motor_group IntakeGroup = motor_group(Intake1, Intake2);
digital_out DigitalOutA = digital_out(Brain.ThreeWirePort.A); //Pneumatics
inertial Inertial6 = inertial(PORT6);
//VEXcode generated functions
//define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
//define variables used for controlling motors based on controller inputs
bool DriveTrainLNeedsToBeStopped_Controller1 = true;
bool DriveTrainRNeedsToBeStopped_Controller1 = true;
bool Controller1LeftShoulderControlMotorsStopped = true;
void pre_auton(void) {
  vexcodeInit();
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
void Autonomous(void) {
  IntakeGroup.spinFor(forward, 1000, rotationUnits::rev, false);
  LeftDriveSmart.spinFor(forward, 2, rotationUnits::rev, false);
  RightDriveSmart.spinFor(forward, 2, rotationUnits::rev);
/*                              User Control Task                            */
/*  This task is used to control your robot during the user control phase of */
void usercontrol(void) {
  while (1) {
    // --- Drivetrain Control ---
    // Calculate drivetrain motor velocity from controller joystick axis
    int drivetrainLeftSpeed = Controller1.Axis1.position() + Controller1.Axis3.position();
    int drivetrainRightSpeed = -1 * Controller1.Axis1.position() - -1 * Controller1.Axis3.position();
    // Deadband check for left side
    if (drivetrainLeftSpeed < 5 && drivetrainLeftSpeed > -5) {
      if (DriveTrainLNeedsToBeStopped_Controller1) {
        LeftDriveSmart.stop();
        DriveTrainLNeedsToBeStopped_Controller1 = false;
    } else {
    // Deadband check for right side
    if (drivetrainRightSpeed < 5 && drivetrainRightSpeed > -5) {
      if (DriveTrainRNeedsToBeStopped_Controller1) {
        RightDriveSmart.stop();
        DriveTrainRNeedsToBeStopped_Controller1 = false;
    } else {
    // Spin left drive motors if outside deadband range
      LeftDriveSmart.setVelocity(drivetrainLeftSpeed, percent);
      LeftDriveSmart.spin(forward);
    // Spin right drive motors if outside deadband range
      RightDriveSmart.setVelocity(drivetrainRightSpeed, percent);
      RightDriveSmart.spin(forward);
    // --- Intake Control ---
    // Check L1/L2 buttons to control intake motors
    if (Controller1.ButtonL1.pressing()) {
      IntakeGroup.spin(forward, 12.0, volt);  // Spin intake forward
    } else if (Controller1.ButtonL2.pressing()) {
      IntakeGroup.spin(reverse, 12.0, volt);  // Spin intake in reverse
    } else {
      IntakeGroup.stop();  // Stop intake motors when buttons are released
    // --- Clamp ---
    // Check R1/R2 buttons to control intake motors
    if (Controller1.ButtonR1.pressing()) {
      DigitalOutA.set(true);
    } else if (Controller1.ButtonR2.pressing()) {
      DigitalOutA.set(false);
  // Wait for a short period to prevent overloading the CPU
  wait(20, msec);
// Main will set up the competition functions and callbacks.
int main() {
  // Set up callbacks for autonomous and driver control periods.
  // Competition.autonomous(Autonomous);
  // Run the pre-autonomous function.
  pre_auton();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
P.s. There is nothing in robot-config.cpp, it is the same as a blank competition template.
You have that line commented, so that might be causing it to not work.
Can you elaborate on this?
The third parameter in motor configurations set the motor to reverse, so:
motor.spin(forward) will go in an opposite direction based on that being true/false.
Does the controller just not work or is some side effect happening when you run the code?
