My team is using PROS for programming. And I found that whenever I attempted to upload the code or run the code on the robot, I got this in the output:
Python path configuration:
PYTHONHOME = 'c:\Users\andre\AppData\Roaming\Code\User
\globalStorage\sigbots.pros\install\pros-cli-windows'
PYTHONPATH = (not set)
program name = 'c:\Users\andre\AppData\Roaming\Code\User\globalStorage\sigbots.pros\install\pros-cli-win
dows\pros.exe'
isolated = 0
environment = 0
user site = 0
import site = 0
sys._base_executable = 'c:\\Users\\andre\\AppData\\Roaming\\Code\\User\\globalStorage\\sigbots.pros\\install\\pros-cli-windows\\pros.exe'
sys.base_prefix = ''
sys.base_exec_prefix = ''
sys.platlibdir = 'lib'
sys.executable = 'c:\\Users\\andre\\AppData\\Roaming\\Code\\User\\globalStorage\\sigbots.pros\\install\\pros-cli-windows\\pros.exe'
sys.prefix = ''
sys.exec_prefix = ''
sys.path = [
'c:\\Users\\andre\\AppData\\Roaming\\Code\\User\\globalStorage\\sigbots.pros\\install\\pros-cli-windows\\base_library.zip',
'c:\\Users\\andre\\AppData\\Roaming\\Code\\User\\globalStorage\\sigbots.pros\\install\\pros-cli-windows\\lib-dynload',
'c:\\Users\\andre\\AppData\\Roaming\\Code\\User\\globalStorage\\sigbots.pros\\install\\pros-cli-windows',
Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding
Python runtime state: core initialized
ModuleNotFoundError: No module named 'encodings'
Is anyone able to help define the error? If so, is there a solution to this error?
