I have been having issues with transmitting data
I have been having issues with transmitting data from one brain to another I have looked over the C++ guide and found that it’s message link and serial link support is not accurate in several ways all I am trying to do is send two int from one brain to another I have also had this weird thing happen in the code were the brain screen prints regularly on the receiving end and after a while replaces the first three characters with zeros.
the code for both programs is down below.
sender code
#pragma region VEXcode Generated Robot Configuration
// Make sure all required headers are included.
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#include <math.h>
#include <string.h>
#include "vex.h"
using namespace vex;
// Brain should be defined by default
brain Brain;
// START V5 MACROS
#define waitUntil(condition)                                                   \
  do {        \
    wait(5, msec);                                                             \
  } while (!(condition))
#define repeat(iterations)                                                     \
  for (int iterator = 0; iterator < iterations; iterator++)
// END V5 MACROS
// Robot configuration code.
controller Controller1 = controller(primary);
// generating and setting random seed
void initializeRandomSeed(){
  int systemTime = Brain.Timer.systemHighResolution();
  double batteryCurrent = Brain.Battery.current();
  double batteryVoltage = Brain.Battery.voltage(voltageUnits::mV);
  // Combine these values into a single integer
  int seed = int(batteryVoltage + batteryCurrent * 100) + systemTime;
  // Set the seed
  srand(seed);
void vexcodeInit() {
  //Initializing random seed.
  initializeRandomSeed();
// Helper to make playing sounds from the V5 in VEXcode easier and
// keeps the code cleaner by making it clear what is happening.
void playVexcodeSound(const char *soundName) {
  printf("VEXPlaySound:%s\n", soundName);
  wait(5, msec);
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
#pragma endregion VEXcode Generated Robot Configuration
// Include the V5 Library
#include "vex.h"
// Allows for easier use of the VEX Library
float myVariable;
// "when started" hat block
int whenStarted1() {
  return 0;
message_link link1 = message_link(PORT9, "link", linkType::manager);
message_link link2 = message_link(PORT9, "link", linkType::manager);
int main() {
  vexcodeInit();
    while (1) {
      int Left = Controller1.Axis3.position();
      int Right = Controller1.Axis2.position();
      if (Left == 0) {
        link1.send("a",6);
     else if (Left > 0) {
       if (Left > 25) {
          link1.send("b",8);
       link1.send("c",10);
      else {
       if (Left > -25) {
           link1.send("d",12);
     if (Right == 0) {
        link2.send("a",7);
     else if (Right > 0) {
        if (Left > 25) {
           link2.send("b",9);
        link2.send("c",11);
     else {
       if (Right > -25) {
          link2.send("d",13);
Receiver code.
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <string.h>
#include "vex.h"
brain Brain;
// START V5 MACROS
  do {        \
    wait(5, msec);                                                             \
// END V5 MACROS
motor Motor9 = motor(PORT9, ratio18_1, false);
motor Motor20 = motor(PORT20, ratio18_1, false);
  // Set the seed
  srand(seed);
  wait(5, msec);
#include "vex.h"
int main() {
  vexcodeInit();
  float drive1 = 0;
  float drive2 = 0;
  message_link link1 = message_link(PORT10, "link", linkType::worker);
  message_link link2 = message_link(PORT10, "link", linkType::worker);
  while (1) {
   if (link1.receive("a",30)) {
      float drive1 = 0;
   else if (link1.receive("c",30)) {
      if (link1.receive("d",30)) {
        float drive1 = 100;
      else {
        float drive1 = 25;
   else {
       float drive1 = -25;
      else {
        float drive1 = -100;
   if (link2.receive("a",30)) {
      float drive2 = 0;
   else if (link2.receive("c",30)) {
      if (link2.receive("b",30)) {
        float drive2 = 100;
      else {
        float drive2 = 25;
   else {
       float drive2 = -25;
      else {
        float drive2 = -100;
   if (drive1 == 0 ) {
     Brain.Screen.print("instruction right off sent");
    Brain.Screen.setCursor(3, 3);
    if (drive2 == 0) {
      Brain.Screen.print("instruction left off sent");
    Brain.Screen.setCursor(1, 1);
    Motor9.setVelocity(drive1, percent);
    Motor20.setVelocity(drive2, percent);
    Motor9.spin(forward);
    Motor20.spin(forward);
