Please share code (put three backticks (```) before and after the code)
Check the line that the brain says, I think it says line 99, there could be an error in that line of code. If you sent the code I could check for you.
your problem is that you have a break
or continue
in your code that is not in a loop. These need to be in a loop otherwise it causes an error. (Also, your error is on line 99)
Tysm!
I fix the error from change the program
