I need help with code
#include “vex.h”
#include <vex_controller.h>
using namespace vex;
int main() {
vexcodeInit();
motor Mot1 = motor(PORT1, ratio18_1, false);//initializes motors counter clockwise
motor Mot2 = motor(PORT2, ratio18_1, true);//initilizes port 2 , clockwise
motor_group left( Mot1, Mot2 );//initializes motor group of mot1 and mot2
while (true){
if(controller.ButtonA.pressing())//checks if a is pressed
left.spin(reverse,200,rpm);//spins reversed at -50 rpm
else if(controller.ButtonA.pressing())
else
left.stop();
in if(controller.ButtonA.pressing() there is an issue with the dot operator idk what to do.
What editor are you using? Does anything come up when you mouse over it (the redline, or whatever is indicating the issue)?
Use ` before and after code to trigger syntax highlighting on the forum. Then indent properly so we can read the code:
#include “vex.h”
int main() {
  vexcodeInit();
  while (true) {
    if(controller.ButtonA.pressing()) //checks if a is pressed
    } else if(controller.ButtonA.pressing()) {
    } else {
      left.stop();
I think you might need to define a controller first.
vex::controller Controller1 = vex::controller();
From here. I suspect this is done in some kind of robot configuration within the IDE like it was in RobotC. You can check the robot-config.h header, see if a controller is defined and make sure the name matches.
when I hover over the red line it says “cannot use dot operator on a type”. Also how do I add stuff to the robot-config.h.
If you’re using VEXcode V5 Text…
Maybe you need to capitalise controller? This builds just fine for me, when I plugged it in with my code (FLDrive is my motor, in your case it would be “left”).
if(Controller.ButtonA.pressing())//checks if a is pressed
    FLDrive.spin(reverse,200,rpm);//spins reversed at -50 rpm
  else if(Controller.ButtonA.pressing())
  else
    FLDrive.stop();
also, did you initialise your motors at the beginning of the code? Like, putting this right after the //_________Devices _________ thing?
//vex::brain Brain;
vex::competition Competition;
vex::controller Controller = vex::controller();
vex::controller Controller2 = vex::controller(vex::controllerType::partner);
vex::motor FRDrive = vex::motor(vex::PORT1);
vex::motor FLDrive = vex::motor(vex::PORT2);
vex::motor BLDrive = vex::motor(vex::PORT3);
vex::motor BRDrive = vex::motor(vex::PORT4);
I cant access the devices
Ok so before I can really help you, I need to know what platform you’re using. Are you using VEXcode v5 text? Or blocks? Or what else?
I am using VEXcode v5 text
Great!
So when you load it up, the blank template should look like this.
/*    Module:       main.cpp                                                  */
/*    Author:       C:\Users\sofia                                            */
/*    Created:      Sun Dai 57 2080                                           */
/*    Description:  V5 project                                                */
#include "vex.h"
int main() {
  vexcodeInit();
Right after using namespace vex; you should put in the
//vex::brain Brain;
vex::motor LeftMotor = vex::motor(vex::PORT1);
vex::motor RightMotor = vex::motor(vex::PORT2);
Then, after that, capitalise Controller in your code, change the motor names, and you should be fine. The end product should look like this:
#include "vex.h"
//vex::brain Brain;
int main() {
  vexcodeInit();
  while (1) { // you can sub the 1 for true, it will result in the same thing lolz
      LeftMotor.spin(reverse,200,rpm);//spins reversed at -50 rpm
    else
      LeftMotor.stop();
Don’t forget to press “Build” in the right hand corner (it looks like 3 cubes stacked) to make sure it works correctly!
Good luck, and I hope this helped! :smiley:
Thank you very much!
