/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Controller1 controller
// Controller2 controller
// Motor2 motor 2
// Motor8 motor 8
// Motor11 motor 11
// Motor20 motor 20
#include "vex.h"
using namespace vex;
competition Competition;
void pre_auton(void) {
vexcodeInit();
void autonomous(void) {
Motor11.startRotateFor(30*360,vex::rotationUnits::deg, 100, vex::velocityUnits::pct);
Motor20.rotateFor(30*360,vex::rotationUnits::deg, 100, vex::velocityUnits::pct);
void usercontrol(void) {
while (1) {
Motor11.spin(directionType::fwd, Controller1.Axis3.value(), velocityUnits::pct);
Motor20.spin(directionType::fwd,Controller1.Axis2.value(), velocityUnits::pct);
if (Controller2.ButtonL1.pressing()) {
Motor2.spin(vex::directionType::fwd, 75,velocityUnits::pct);
Motor8.spin(vex::directionType::fwd, 75,velocityUnits::pct);
} else if (Controller2.ButtonL2.pressing()) {
Motor2.spin(vex::directionType::rev, 75,velocityUnits::pct);
Motor8.spin(vex::directionType::rev, 75 ,velocityUnits::pct);
} else {
Motor2.stop(brakeType::hold);
Motor8.stop(brakeType::hold);
wait(20, msec);
int main() {
//Run the pre-autonomous function.
pre_auton();
//Set up callbacks for autonomous and driver control periods.
Competition.autonomous( autonomous );
Competition.drivercontrol( usercontrol );
//Prevent main from exiting with an infinite loop.
while(1) {
vex::task::sleep(100);//Sleep the task for a short amount of time to prevent wasted resources.
The bits of the message you omitted would have more information about what’s wrong
Can you upload the whole folder with all of the code in the robot-config.cpp file I have had many errors.
The most common mistake that causes [error]: make process closed with exit code: 2
is having spaces in the program or folder name. See this topic:
