So my pneumatics kits air chamber puts out no air to the solinoid at all and dose not trigger the pistons i really need help
Can we get a photo or possibly a video? If not, can you please give more context on what you mean by puts out no air?
First, look closely at the tubes to see if there is a leak. You can also try checking the wiring for the air pump. Also to make sure you’re setting up the solenoid to the piston right. Creator Academy Australia(YouTube channel) has a good video to show you the basics on how to put it together.
Last year there was a leak in our pneumatics right before states so we had to be silent and just listen on to the leaks and find them and replace the tubing or tighten it in better.
did you put it in the tubes in the right port
I doubt it’s the tubes, people often leave a opening on solenoids and air is lost easily.
