I put arcade split but bot is tank drive
This is my first time using Ez Template and as Im setting it up so it is similar to our old code and we were using arcade split, but when I put chassis.opcontrol_arcade_standard(ez::SPLIT); under void opcontrol(){
} it still is in tank drive. im coding in vscode and I don’t have the vex extension just github, c++, and pros
Try cleaning the project and redownloading it.
In the PROS Integrated terminal run:
pros make clean
then build and download the project
also make sure the line for tank drive is commented out:
								   // chassis.opcontrol_tank();  // Tank control
		chassis.opcontrol_arcade_standard(ez::SPLIT);   // Standard split arcade
								   // chassis.opcontrol_arcade_standard(ez::SINGLE);  // Standard single arcade
								   // chassis.opcontrol_arcade_flipped(ez::SPLIT);    // Flipped split arcade
								   // chassis.opcontrol_arcade_flipped(ez::SINGLE);   // Flipped single arcade
Hope this helps!
I did that and now the left stick controls drivetrain except one side is spinning the wrong way and the right stick controls the right side and the motor on port 5
