I got bored, so I decided to mess with RobotC settings. Yeah… I quickly encountered problems with Kiosk mode (to me it’s useless, like why is it even there). I discovered there is a solution folder panel which is amazing, however, you can only look at files, not folders unless I’m doing it wrong (probably). Then I discovered that I can change the font, so I looked for Comic Sans MS and couldn’t find it… then I decided to try out Terminal, and after applying, the text spacing and formatting was all off, with some text overlapping others. Then after fixing the Kiosk mode problem, I found out that my text functions panel was broken. I like working in Super User window mode, and usually, it offers more functions in the functions panel. But now… I don’t get it. So if anyone knows how to 1) display folders in the “Solution Explorer View”, 2) fix my “Function Library View”, and 3) enable Comic Sans and/or know how to fix the weird text overlaying problem if I change to a different font than the default. Thank you in advance.
