Hi my team was wondering what the best customization ideas for ike to make it higher to pick up cubes
Who is “ike”
Anyways, You could make a telescoping tray or add another section that folds up.
This is Ike: https://content.vexrobotics.com/vexiq/pdf/228-4444-753_web%20Rev1-20150901.pdf
The easiest way would be to lengthen the arms.
ike is one of the robot builds
thank yo also do you know about where to find how to lengthen the arms.
ike is the robot build
Ike is a “funbot”…a build not really intended to play a game. You’ll need to figure out your own modifications.
thank you for the information
@kmmohn said it’s a funbot, but it’s not too bad with this years game. With a little bit of modification Ike can get arms around the cubes. When running across the floor Ike needs to lean back to carry the cube, so he doesn’t fall over.
I’m not going to give you exact instructions, but with a little effort you should be able to figure it out. But i will say some rubber bands to help the grip will be an idea to look at.
Good luck!
