Im having trouble with this catapult code
I am having trouble with this code here. Everything works fine except when i press b, the catapult doesn’t go down. I’m not sure how to fix it. Any thoughts?
while (1){
//Drive Control
//Set the left and right motor to spin forward using the controller Axis values as the velocity value.
//Since we are using a single joystick, we will need to calculate the final volicity for each motor.
Left.spin(vex::directionType::fwd, (Controller1.Axis3.value() + Controller1.Axis4.value()), vex::velocityUnits::pct); //(Axis3+Axis4)/2
Right.spin(vex::directionType::fwd,(Controller1.Axis3.value() - Controller1.Axis4.value()), vex::velocityUnits::pct);//(Axis3-Axis4)/2
BackLeft.spin(vex::directionType::fwd, (Controller1.Axis4.value() + Controller1.Axis3.value()), vex::velocityUnits::pct); //(Axis4+Axis3)/2
BackRight.spin(vex::directionType::fwd,(Controller1.Axis4.value() - Controller1.Axis3.value()), vex::velocityUnits::pct);//(Axis4-Axis3)/2
           //BallLoader Control
        if(Controller1.ButtonL1.pressing()) { //If buttonl1 is pressed...
               //...Spin the motor forward.
            Loader.spin(vex::directionType::fwd, 50, vex::velocityUnits::pct);
        else if(Controller1.ButtonL2.pressing()) { //If buttonl2 is pressed...
            //...Spin the motor backward.
            Loader.spin(vex::directionType::rev, 50, vex::velocityUnits::pct);
        else { //If the the buttons are not pressed...
            //...Stop the motor.
            Loader.stop(vex::brakeType::coast);
    if (Controller1.ButtonR2.pressing())
        Catapult.spin(vex::directionType::fwd, 100,vex::velocityUnits::pct);
    else if (LimitSwitch.pressing())
        Catapult.stop(brakeType::hold);
    if (Controller1.ButtonB.pressing())
        Catapult.spin(vex::directionType::fwd, 50,vex::velocityUnits::pct);\
Is the Catapult pressing the LimitSwitch, when you’re wanting the B button to make it go farther down? With the previous code, the B button wouldn’t do anything when the Limit switch was pressed.
The adjusted code below, you’d can hold down the B button and it would continue even when the limit switch is pressed. I assume this would allow the catapult to engage the way you want.
The code had a lot of extra brackets that you won’t need.
while (1)
	//Drive Control
	else if (Controller1.ButtonB.pressing())
You can post your code with Syntax Highlighting to make it easier to read:
Thank you for your help!
Just FYI, this isn’t the category to post this in. Try #edr-technical-support
