IME problem
Hi
I am having an issue with an IME. It is the last one in the chain and the light blinks green as the others. I use it for my extreme limit and it has been solid. I converted the 393 to high speed and that is where the problem began. The value used to be 0 for all the way in and 3074 for all the way out. Now the value appears to count to 1000 then start back at 0. Any help would be appreciated. I use the lcd in driver control to get the values and I reset the IME at the start of driver control.
Sorry I had an lcd issue. I ran out of digits on the display. The IME is fine. That’s what happens when you spend too much time in front of the computer.
