Is it possible to write the PID output to a variable in order to assign it to two motors (one with IME, one without IME) as shown with one encoder in the IME PID example in the following link? Thanks!
We do not recommend doing that. If one motor binds, the loop will have no feedback to adjust that motor.
But you can get that information using the PID Debug Feature.
See, under the help file: easyC V4 for Cortex Advanced Features Get Integrated Motor Encoder PID Data
ok thanks for info. can the IME PID function write directly to a variable which would later be assigned to two motors on the same side of our chassis (physically chained together)?
ok thankyou for the clarification. i was attempting to send the PID output to a variable and from there send that to a motor. would the smart task you described be able to control two motors that are physically linked with only one having the encoder or would i need to write that to a variable from there? thanks for all your help.
i think that i have solved my issue by using the smart tasks. my whole thing was that i was trying to not have to use y cables as i have one of the motors in a 2 wire port and the other in a 3 wire port with a motor controller on it. so the smart tasks ended up to be a better option anyways.
