In VEXcode Pro v5, How to manually edit “robot-config.cpp” ?
Automatically Generated Code - Enable “Expert Robot Configuration” to manually edit. But I can’t find where to Enable.
You should be able to enable expert mode by clicking the top where you would do things like change your program’s name. But if you are comfortable enough with C++ to declare electronics yourself, it might be worth it for you to look into PROS and Okapilib, which raises the floor a ton.
