Inconsistent code, help!
Every time I push the limit switch the variable is a different number? Why? It should just add 1 every time? How can I fix this. I the LED is to turn on after 10 hits on the limit switch and the bumper resets the count and turns off the light.
#pragma config(Sensor, dgtl1,  limitswitch,    sensorTouch)
#pragma config(Sensor, dgtl2,  bumper,         sensorTouch)
#pragma config(Sensor, dgtl12, led,            sensorLEDtoVCC)
task main()
	bool buttonPressed=false;
	int counter = 0;
	while(true){writeDebugStream("int counter is: %d", counter);
		if(SensorValue[limitswitch]==1 && buttonPressed==false){
			buttonPressed=true;
			counter+=1;
			while(SensorValue[limitswitch]==1){
		else if(SensorValue[limitswitch]==0 && buttonPressed==true){
		if(SensorValue[bumper]==1){
			counter=0;
		if(counter>=10){
			SensorValue[led]=true;
		else{
			SensorValue[led]=false;
Add a wait1Msec(100); at the end of the while loop.
Thank You, that fixed it but now it is not turning on the LED?? Here is the code-
#pragma config(Sensor, dgtl10, limitswitch,    sensorTouch)
#pragma config(Sensor, dgtl11, bumper,         sensorTouch)
task main()
	int counter = 0;
			buttonPressed=true;
			counter+=1;
			wait1Msec(100);
			counter=0;
		if(counter>=10){
		else{
Never mind about the LED… I didn’t have my cortex battery on or on. Thank You for your help.
No probem, I’m glad you were able to figure it out.
