Inertial commands are not being accepted
My team recently got an inertial sensor, and when I found the commands to use the inertial sensor none of them worked. Is there some set up code I need in the pre auton to make it work? every time I use “TurnToHeading” or “spinTo” it says it is an error. I have also tried different capitalizations for the commands, and I looked through the command list in Vexcode but I didn’t find any commands for the inertial sensor.
The turnToHeading and spinTo methods only work if you are using a Drivetrain object.
If you set up your motors manually, those methods will throw errors.
Generally, an Inertial sensor is used less for direct turnTo’s and more for tracking heading for PID loops.
Hope this helps! :slight_smile:
