Inertial Pros
Hey guys I need help programming my inertial sensor in PROS I just cant seem to modify the code from vex code. (I just changed over from vex code). Do you guys have any code on the inertial that you’re willing to share?
Hi Error101,
What do you mean by this? Are you saying that your VEXCode code doesn’t work in PROS? If so, I recommend you check out our documentation on the Inertial Sensor for PROS.
https://pros.cs.purdue.edu/v5/api/cpp/imu.html?highlight=inertial
