Hello! Our team is trying to use a new inertial sensor. Viewing the inertial sensor data under the home → devices → sensor port works, we can see heading, pitch, roll, and more data. When we try to program the inertial sensor to read data, we get 0s for heading, yaw, angle, rotation, pitch, and roll functions. Could anyone help out? I feel like we’re missing a step in the setup that shouldn’t be hard to find, though I can’t find inertial code examples online that look different than ours.
#include "vex.h"
#include "Timer.h"
#include <thread>
using namespace vex;
using signature = vision::signature;
using code = vision::code;
// A global instance of brain used for printing to the V5 Brain screen
brain Brain;
// VEXcode device constructors
motor leftDrive = motor(PORT1, ratio18_1, false);
motor rightDrive = motor(PORT2, ratio18_1, true);
gyro TurnGyroSmart = gyro(Brain.ThreeWirePort.D);
inertial IntertialSeneor = inertial(11);
smartdrive Drivetrain = smartdrive(leftDrive, rightDrive,
TurnGyroSmart, 319.19, 320, 130, mm, 1);
// VEXcode generated functions
* Used to initialize code/tasks/devices added using tools in VEXcode Pro.
* This should be called at the start of your int main function.
static bool stopVexProgram = false; // Below below
long long currentTime = 0; // And below
Timer checkErrors{"AAA"}; // Outside since vex's thread implementation is a little less free than C++'s
double totDegrees = 0; // Outside for the same reason as above
void startSecondThread() {
while(!stopVexProgram) {
long long time = checkErrors.getTime() - currentTime;
Brain.Screen.printAt(10, 40, "Angles: %.4f", IntertialSeneor.yaw());
if(time >= 5000) {
Brain.Screen.printAt(10, 20, "Main thread is stalling!");
} else {
Brain.Screen.printAt(10, 20, "Main thread is working! ");
this_thread::sleep_for(20);
void vexcodeInit(void) {
IntertialSeneor.calibrate();
checkErrors.start();
thread errorChecker{startSecondThread};
Timer programLoop{"Total runtime"};
programLoop.start();
int tick = 0;
if(tick >= 4) {
stopVexProgram = true;
break;
// Loop inside here
// 30 * 3.14 * 1/4 = each wheel
// 180 degrees = 10.5
double distanceBetweenWheels = 29.5; // Centimeters
double wheelDiameter = 10.5; // Centimeters
double distance = distanceBetweenWheels * M_PI_2; // We don't divide by 4 since we're using 2 wheels to turn
double rotations = distance / wheelDiameter;
// totDegrees is outside of the function due to some lambda weirdness down below
totDegrees = (rotations * 180. / M_PI);
Drivetrain.setDriveVelocity(75, percent);
Drivetrain.driveFor(6*11, inches);
Drivetrain.setDriveVelocity(20, percent);
if(tick < 3) { // Don't do the last rotation to save time
// Run one of the motors on another thread so both can turn simultaneously using a lambda
while(IntertialSeneor.yaw() < 88) {
thread dd{[](){leftDrive.spin(directionType::fwd);}};
rightDrive.spin(directionType::rev);
leftDrive.stop();
rightDrive.stop();
currentTime = checkErrors.getTime();
tick++;
double totalTime = (((double) programLoop.getTime()) / 1000.);
Brain.Screen.printAt(10, 40, "Total time to run program: %f", totalTime);
