I’m trying to create a PID for my robot’s rotation using Vexcode, but whenever I try to run multiple 90 degree turns, some of the turns are way off while others are perfectly fine.
double kPAngle = 0.1;
double kIAngle = 0.0;
double kDAngle = 0.0;
double maxSpeed = 6;
void rotatePID(double angleTurn) {
double error = 0;
double prevError = 0;
double derivative = 0;
double integral = 0;
while( fabs(iSensor.rotation() - angleTurn) > 0.5) {
error = angleTurn - iSensor.rotation(rotationUnits::deg);
derivative = error - prevError;
prevError = error;
if(fabs(error) < 5 && error != 0) {
integral += error;
else {
integral = 0;
double powerDrive = error*kPAngle + derivative*kDAngle + integral*kIAngle;
if(powerDrive > maxSpeed) {
powerDrive = maxSpeed;
else if(powerDrive < -maxSpeed) {
powerDrive = -maxSpeed;
cout << "power: " << powerDrive << endl;
cout << "angle: " << iSensor.rotation() << endl;
cout << "error: " << error << endl;
// cout << "prevError: " << prevError << endl;
// cout << "derivative: " << derivative << endl;
// cout << "integral: " << integral*kIDrive << endl;
cout << "////" << endl;
// turning = true;
// goalVoltage = powerDrive;
rightDt.spin(rightSide, powerDrive, voltageUnits::volt);
leftDt.spin(leftSide, powerDrive, voltageUnits::volt);
this_thread::sleep_for(15);
// turning = false;
// goalVoltage = 0;
dt.stop(brake);
iSensor.calibrate(2000);
this_thread::sleep_for(2000);
cout << "Done calibrating" << endl;
iSensor.setRotation(270.00, rotationUnits::deg);
cout << "Rotation: " << iSensor.rotation() << endl;
rotatePID(180);
this_thread::sleep_for(1000);
rotatePID(90);
rotatePID(0);
rotatePID(-90);
I have the robot doing four 90 degree turns here and some of the turns are perfectly on point, while others are off by more than 5 degrees. The inertial sensor still records the angles are correct (e.g. will say its at 90 degrees) but will obviously not be at 90 degrees when looking at the robot. I’m not sure what’s causing this, but I do know that our robot’s imbalanced; however, this should not effect the angle the inertial sensor calculates.
