Is the inertial sensor yet supported in VexCode? If it is, what is it called so I can initialize it in robot configuration.
Thanks!
Thanks!
Thanks, I see that has a file I need to include that I dont have, do I need to copy and paste the code in vex_imu.h to a header file?
I do not believe so, if you are using the most updated version of VEXCode, it shouldn’t be a problem. Once you have the most updated version it will automatically download that file (though you won’t see it in your ‘src’ or ‘include’ folders).
Oh ok, Maybe I need to update my VEXCode.
Do that, and then try initializing it and if autocomplete finishes it, then you are all set.
