So… If your robot tips sideways that is higher than 48 inches due to any reason, will the height limit be considered adjacent with the robot or adjacent with the field?
Basically what I am saying is that will it be legal to have a robot extend as high as possible with a drivetrain on the side instead of on the bottom, and have the robot intentionally tip creating a base “wider” than 48 inches?
If you tip unintentionally, I doubt they’ll dq you. However, if part of your robots functionality is tipping you’ll probably be considered outside the size limit if you remain longer than 48 inches.
