I get the following warning
Warning:Use ‘inline’ to avoid possible simultaneous variable memory access conflicts for subroutine ‘startMotor’ called from multiple tasks ‘conveyer’ and ‘main’?
should I be worried?
Here is the code
task drive () //driving program to run parallel to lifting and delivering
while (1==1)
motor[rightMotor] = (vexRT[Ch2]);
motor[leftMotor] = (vexRT[Ch3]);
task conveyer() /task conveyor runs the conveyor belt when button 6U is
pressed and runs backwards when 6D is pressed/
while (1==1)
while (vexRT[Btn6U]==1)
startMotor(conv1, 127);
startMotor(conv2, 127);
while (vexRT[Btn6D]==1)
startMotor(conv1, -127);
startMotor(conv2, -127);
stopMotor(conv1);
stopMotor(conv2);
task main() //task main is the lifting program
StartTask (drive);
StartTask (conveyer);
SensorValue[encoder] = 0;
while(1==1)
while(vexRT[Btn5U] == 1) //high goal
if(SensorValue[encoder]<=1200) //holding pattern for high goal
startMotor(lift1,127);
startMotor(lift2, 127);
else
stopMotor(lift1);
stopMotor(lift2);
while(vexRT[Btn7U] == 1) //go to medium goal
if(SensorValue[encoder]<=800) //holding pattern for medium goal
else
stopMotor(lift1);
stopMotor(lift2);
while(vexRT[Btn7L] == 1) //go to low goal
if(SensorValue[encoder]<=360) //holding pattern for high goall
startMotor(lift2,127);
else
stopMotor(lift1);
stopMotor(lift2);
while (vexRT[Btn5D] == 1) //lower the lift
startMotor(lift1, -50);
startMotor(lift2, -50);
stopMotor(lift1);
stopMotor(lift2);
} //end of forever loop
} //end of task main
