Intake coming out of the motor
So the intake come out of the motor and causing it to not spin in the middle of a Mach
That’s crazy, did you try pushing it back in?
This is where it attaches to the motor.
There is a mental bar running all the way across the intake through the grey plate and into the motor
does anyone have and ideas on how to fix this??
If so pls share!!
Yes but it keeps coming out
Did you try using a better motor
I have tried changing out the motor but it still comes out
Maybe you weren’t pushing it hard enough
Oh my team mate just put a rubber band on the bottom to keep the two pieces to keep it from coming out but that’s you for responding so fast and the great ideas!!
The yellow line is a rubber band
is the COG of the motor good? that could be the problem
The motor looks cantilever so fixing that might fix your problem.
i couldnt agree more
You may want to try using 2 collars on the shaft that’s connected to the motor. I see what looks like a collar on the end of the shaft against the small sprocket and chain. Do you have a corresponding collar between the roller and the 4x beam that is connected to the chain? Placing a collar there will prevent movement away from the motor and help keep the shaft in the motor.
