So I’ve figured the easiest way to have my intakes rotate is to have it on an axle and motor. However, the intakes are too heavy and tend to fall out. I have rubber locking collars on the shafts but they seem to just slide down. Any suggestions (I have already reduced it size by 1/3 in order to cut weight)
- reduce weight where possible
- Use shaft collars if you weren’t before
3)More shaft collars
Hope this helps if not, ignore me
Clamping shaft collar, my dude.
Yeah, the rubber collars aren’t any good and I have yet to find a decent application for them other than as weird spacer things.
