Intake questions
  1. Do you need a whole row of flex wheels for the intake or should you leave a little space in the middle so that the triball can like sort of fit in the intake?
  2. Is it better to have the triball still touching the floor after intaking or slightly in the air? (like using the ground as the triball support on the bottom or having a hs axle or standoff underneath it)
  3. Should you use hs axles for each gear or have screw joints on the cata gears?
Thanks
  1. test and see what works best for your design I have done both and both do certain things well.
  2. also should do some testing as it depends on your preference as a driver
    3.for cata I would definitely do HS axels. reduces chance of failure.
Can you send a picture of the intake?
