Is there any way one can put Turbo gears into the Integrated Motor Encoders? From what I understand, they come with the painted non-turbo/high speed regular gears.
The gearing for the motors is at the front of the motor (the side with the screw in pegs). The back green side of the motor gearing is where the IME gears go. Turbo gears being put in place won’t affect the IME colored gears.
Well, technically they will affect the ime (it will be 2.6 times less precise) but you are correct that you can still use both.
