iPad & Vex IQ Brain bluetooth connectivity
My students are using iPads with VexCode to program IQ robots. Several can not connect to the robot brain via bluetooth. All updates on Brain are current. Please advise
did you make sure that bluetooth was enabled on the brains?
sounds like a stupid question, but that could possibly get overlooked
What types of Ipads are ur students using,
This is worth checking - there is an option called Radio Data in the settings. Make sure it is on.
And if you select the ā€œreset all settingsā€ option on the brain then the radio data option will be reset to off.
See this support article for more troubleshooting steps.
iPad (7th generation) with 13.5.1 software
Ya, it should work, Just make sure ur bluetooth is on and ur Radio Data for ur VexIq brain is on
