(IQ C++) Global pointer causes compilation error
hopefully this is correct, getting this under the 32k forum post limit was a bit awkward
code part 2
/*  Check the touch LED and color sensors                                      */
void
iqCheckSensors()
    static bool robotTouchSensorPressed;
    // Touch LED
    if( robotTouchSensor.installed() ) {
        if( robotTouchSensor.pressing() ) {
            if(!robotTouchSensorPressed) {
                robotEnabled = !robotEnabled;
                robotTouchSensorPressed = true;
        else {
            robotTouchSensorPressed = false;
    // Color sensor
    if( robotColorSensor.installed() ) {
        // close object ?
        // TODO !
        if( robotColorSensor.value() > 200 ) {
            colorType  color;
            color = robotColorSensor.colorname12();
            if( color == colorType::red )
                robotEnabled = false;
            if( color == colorType::green )
                robotEnabled = true;
    // Display enabled status on the touch LED
    if( robotTouchSensor.installed()) {
        if( robotRunning ) {
            if(robotEnabled)
                robotTouchSensor.on(colorType::green);
            else
                robotTouchSensor.on(colorType::red);
        else
            robotTouchSensor.on(colorType::none);
/*  Task used to drive the robot and handle all the discovered sensors         */
int
iqRunRobotTask()
    while(1)
        // Request to kill this task, we need to cleanup first
        // set to disabled to stop motors
        if( !robotRunning )
        // Drive motors
        iqRunRobotDrive();
        // Aux motors
        iqRunRobotAux();
        // Check sensors
        iqCheckSensors();
        // done
        if( !robotRunning )
          break;
        // Don't hog the cpu
        task::sleep(25);
      return(0);
/*  Calibrate gyro if installed                                                */
void
iqCalibrateGyro()
    if( robotGyroSensor.installed() ) {
        short count = 20;
        // VEX sets touch sensor yellow when calibrating
            robotTouchSensor.on( colorType::yellow );
        robotGyroSensor.startCalibration(gyroCalibrationType::calNormal);
        // delay so calibrate flag can be set internally to the gyro
        task::sleep(100);
        Brain.Screen.clearScreen();
        // wait for calibration to finish or 2 seconds, whichever is longer
        while( robotGyroSensor.isCalibrating() || (count-- > 0) ) {
            char str[32];
            sprintf( str, "Calibrating...     %02d", count/10 );
            Brain.Screen.printAt( 1, 1, str);
            task::sleep(100);
        // reset so this is 0 heading
        robotGyroSensor.resetHeading();
/*  Display one line on the IQ display with inverted text if selected          */
void
iqDisplayLine( int row, bool select, const char *str )
    if( row < 1 || row > 5 )
        return;
    int ypos = (row-1) * 11;
    Brain.Screen.setPenColor( colorType::white );
    Brain.Screen.setFillColor( colorType::white );
    if( select ) {
      Brain.Screen.drawRectangle( 0, ypos, 128,11);
      Brain.Screen.printAt( row, 1, str );
      Brain.Screen.invertRectangle( 0, ypos, 128, 11);
    else {
      Brain.Screen.drawRectangle( 0, ypos, 128, 11);
/*  Redisplay the configuration menu                                           */
void
iqMenuConfigurationDisplay( tConfigSelect selected, int offset )
    char  str[32];
    int rowOffset = offset * -1;
    iqDisplayLine( LCD_ROW1 + rowOffset, selected == kConfig_exit, "Exit                 " );
    switch( configDriveMode )
        case  kJoystickTank:        strcpy( str, "Control   2 Joystick "); break;
        case  kJoystickArcadeLeft:  strcpy( str, "Control   Left Stick "); break;
        case  kJoystickArcadeRight: strcpy( str, "Control   Right Stick"); break;
        default:                    strcpy( str, "Control   Error      "); break;
    iqDisplayLine( LCD_ROW2 + rowOffset, selected == kConfig_0, str );
    switch( configDriveTurn )
        case  kNormal:  strcpy( str, "DriveTurn Normal     "); break;
        case  kReverse: strcpy( str, "DriveTurn Reverse    "); break;
        default:        strcpy( str, "DriveTurn Error      "); break;
    iqDisplayLine( LCD_ROW3 + rowOffset, selected == kConfig_1, str );
    switch( IQMotors[ PORT1 ].direction )
        case  kNormal:  strcpy( str, "Drive Fwd Normal     "); break;
        case  kReverse: strcpy( str, "Drive Fwd Reverse    "); break;
        default:        strcpy( str, "Drive Fwd Error      "); break;
    iqDisplayLine( LCD_ROW4 + rowOffset, selected == kConfig_2, str );
    switch( IQMotors[ PORT4 ].direction )
        case  kNormal:  strcpy( str, "Motor 4   Normal     "); break;
        case  kReverse: strcpy( str, "Motor 4   Reverse    "); break;
        default:        strcpy( str, "Motor 4   Error      "); break;
    iqDisplayLine( LCD_ROW5 + rowOffset, selected == kConfig_3, str );
    switch( IQMotors[ PORT5 ].direction )
        case  kNormal:  strcpy( str, "Motor 5   Normal     ");break;
        case  kReverse: strcpy( str, "Motor 5   Reverse    ");break;
        default:        strcpy( str, "Motor 5   Error      "); break;
    iqDisplayLine( LCD_ROW6 + rowOffset, selected == kConfig_4, str );
    switch( IQMotors[ PORT10 ].direction )
        case  kNormal:  strcpy( str, "Motor 10  Normal     ");break;
        case  kReverse: strcpy( str, "Motor 10  Reverse    ");break;
        default:        strcpy( str, "Motor 10  Error      "); break;
    iqDisplayLine( LCD_ROW7 + rowOffset, selected == kConfig_5, str );
    switch( IQMotors[ PORT11 ].direction )
        case  kNormal:  strcpy( str, "Motor 11  Normal     ");break;
        case  kReverse: strcpy( str, "Motor 11  Reverse    ");break;
        default:        strcpy( str, "Motor 11  Error      "); break;
    iqDisplayLine( LCD_ROW8 + rowOffset, selected == kConfig_6, str );
    switch( (int)sonarFront )
        case  1       : strcpy( str, "Sonar     Front      ");break;
        default:        strcpy( str, "Sonar     Rear       ");break;
    iqDisplayLine( LCD_ROW9 + rowOffset, selected == kConfig_7, str );
/*  Action the select button when in the configure menu                        */
/*  returns true if the exit item was selected                                 */
bool
iqMenuConfigurationSelect( tConfigSelect selected )
  switch(selected)
    case  kConfig_exit:
        return( true );
        break;
    case  kConfig_0:
        switch(configDriveMode)
            case  kJoystickTank:        configDriveMode = kJoystickArcadeRight; break;
            case  kJoystickArcadeRight: configDriveMode = kJoystickArcadeLeft;  break;
            case  kJoystickArcadeLeft:  configDriveMode = kJoystickTank;        break;
            default:                    configDriveMode = kJoystickTank;        break;
        break;
    case  kConfig_1:
        configDriveTurn = (configDriveTurn == kNormal) ? kReverse : kNormal;
        break;
    case  kConfig_2:
        // Use motors on port1 and port6 as reference even if they are not installed
        IQMotors[ PORT1  ].direction = (IQMotors[ PORT1  ].direction == kNormal) ? kReverse : kNormal;
        IQMotors[ PORT6  ].direction = (IQMotors[ PORT6  ].direction == kNormal) ? kReverse : kNormal;
        break;
    case  kConfig_3:
        IQMotors[ PORT4  ].direction = (IQMotors[ PORT4  ].direction  == kNormal) ? kReverse : kNormal;
        break;
    case  kConfig_4:
        IQMotors[ PORT5  ].direction = (IQMotors[ PORT5  ].direction  == kNormal) ? kReverse : kNormal;
        break;
    case  kConfig_5:
        IQMotors[ PORT10 ].direction = (IQMotors[ PORT10 ].direction == kNormal) ? kReverse : kNormal;
        break;
    case  kConfig_6:
        IQMotors[ PORT11 ].direction = (IQMotors[ PORT11 ].direction == kNormal) ? kReverse : kNormal;
        break;
    case  kConfig_7:
        sonarFront = !sonarFront;
        break;
    default:
        break;
    return( false );
/*  Action the "configure" menu item                                           */
void
iqMenuConfiguration()
    static  tConfigSelect configSelect = kConfig_exit;
    int *pconfigSelect = (int *)&configSelect;
    static int offset = 0;
    bool done   = false;
    bool update = true;
    bool dirty  = false;
    // Wait for LCD button release
    while( Brain.buttonUp.pressing() || Brain.buttonDown.pressing() || Brain.buttonCheck.pressing())
      task::sleep(10);
    while( !done ) {
        // Display menu
        if( update ) {
            iqMenuConfigurationDisplay( configSelect, offset );
            update = false;
        // Check LCD buttons
        if( Brain.buttonUp.pressing() || Brain.buttonDown.pressing() || Brain.buttonCheck.pressing() ) {
            if( Brain.buttonDown.pressing()  ) {
                if( configSelect == kConfig_7 )
                    configSelect = kConfig_7;
                else
                    (*pconfigSelect)++;
                if( configSelect > kConfig_3 && offset == 0 )
                    offset = 4;
            if( Brain.buttonUp.pressing()  ) {
                if( configSelect == kConfig_exit )
                 else
                    (*pconfigSelect)--;
               if( configSelect < kConfig_3 && offset == 4 )
                    offset = 0;
            if( Brain.buttonCheck.pressing()  ) {
                if( iqMenuConfigurationSelect( configSelect ) ) {
                    if( dirty )
                        iqSettingsStore();
                    done = true;
                else
                    dirty = true;
            // Exit doesn't really work
            //if( nLCDButtons == kButtonExit  ) {
            //    done = true;
            while( Brain.buttonUp.pressing() || Brain.buttonDown.pressing() || Brain.buttonCheck.pressing() )
              task::sleep(10);
            // update display
            update = true;
    task::sleep(25);
    // erase before we leave this sub menu
/*  Function to draw up or down arrow as the LCD character set seems limited   */
void
drawArrow( int xpos, int ypos, bool dir )
    int i;
    //Brain.Screen.setPenColor(colorType::white);
    //Brain.Screen.drawRectangle(xpos, ypos, 8, 5, colorType::white );
    Brain.Screen.setPenColor(colorType::black);
    if( dir ) { // Up arrow
      for(i=0;i<=4;i++)
        Brain.Screen.drawLine( xpos+i, ypos+i, xpos + (8-i), ypos+i );
    else {      // Down arrow
      for(i=0;i<=4;i++)
        Brain.Screen.drawLine( xpos+(4-i), ypos+i, xpos + (4+i), ypos+i );
/*  Display controller status                                                  */
/*  Long form formatting to try and match the VEX version under driver control */
/*  ROBOTC standard text position does not match the VEX display               */
void
iqRunDisplayJoystickStatus()
    // background text
    Brain.Screen.printAt( LCD_ROW1, 1, "Button     Axis" );
    Brain.Screen.printAt( LCD_ROW2, 1, "E" );
    Brain.Screen.printAt( LCD_ROW3, 1, "F" );
    Brain.Screen.printAt( LCD_ROW4, 1, "R" );
    Brain.Screen.printAt( LCD_ROW5, 1, "L" );
    Brain.Screen.printAt( LCD_ROW2, 8, "A" );
    Brain.Screen.printAt( LCD_ROW3, 8, "B" );
    Brain.Screen.printAt( LCD_ROW4, 8, "C" );
    Brain.Screen.printAt( LCD_ROW5, 8, "D" );
    // Display button status
    if( Controller.ButtonEDown.pressing() )
        drawArrow( 13, (LCD_ROW2*11)-8, false );
    else
        Brain.Screen.printAt( LCD_ROW2, 3, "  " );
    if( Controller.ButtonEUp.pressing() )
        drawArrow( 25, (LCD_ROW2*11)-8, true );
    else
        Brain.Screen.printAt( LCD_ROW2, 5, "  " );
    if( Controller.ButtonFDown.pressing() )
        drawArrow( 13, (LCD_ROW3*11)-8, false );
    else
        Brain.Screen.printAt( LCD_ROW3, 3, "  " );
    if( Controller.ButtonFUp.pressing() )
        drawArrow( 25, (LCD_ROW3*11)-8, true );
    else
        Brain.Screen.printAt( LCD_ROW3, 5, "  " );
    if( Controller.ButtonRDown.pressing() )
        drawArrow( 13, (LCD_ROW4*11)-8, false );
    else
        Brain.Screen.printAt( LCD_ROW4, 3, "  " );
    if( Controller.ButtonRUp.pressing() )
        drawArrow( 25, (LCD_ROW4*11)-8, true );
    else
        Brain.Screen.printAt( LCD_ROW4, 5, "  " );
    if( Controller.ButtonLDown.pressing() )
        drawArrow( 13, (LCD_ROW5*11)-8, false );
    else
        Brain.Screen.printAt( LCD_ROW5, 3, "  " );
    if( Controller.ButtonLUp.pressing())
        drawArrow( 25, (LCD_ROW5*11)-8, true );
    else
        Brain.Screen.printAt( LCD_ROW5, 5, "  " );
    // Display controller value
    Brain.Screen.printAt( LCD_ROW2, 12, "%+4d", Controller.AxisA.value() );
    Brain.Screen.printAt( LCD_ROW3, 12, "%+4d", Controller.AxisB.value() );
    Brain.Screen.printAt( LCD_ROW4, 12, "%+4d", Controller.AxisC.value() );
    Brain.Screen.printAt( LCD_ROW5, 12, "%+4d", Controller.AxisD.value() );
    // Percent symbol needs fixing somehow (reversed??)
    // and dropped one line
    Brain.Screen.printAt( LCD_ROW2, 16, "%%");
    Brain.Screen.printAt( LCD_ROW3, 16, "%%");
    Brain.Screen.printAt( LCD_ROW4, 16, "%%");
    Brain.Screen.printAt( LCD_ROW5, 16, "%%");
/*  Display device status information when running                             */
void
iqRunDisplayDeviceStatus( int page )
    IQ_DeviceType       type;
    short               index;
    short               port;
    short               deviceCount = 0;
    short               deviceStart = (page * 4) + 1;
    short               displayRow  = LCD_ROW1;
    Brain.Screen.printAt( LCD_ROW1, 1, "Port      Status" );
    if( robotTotalDevices == 0 )
        return;
    // Get all device info
    for(index=(short)PORT1;index<=(short)PORT12;index++) {
        port = index + 1;
        type = vex::device(index).type();
        // found a device
        if( type != kDeviceTypeNoSensor )
          deviceCount++;
        else
          continue;
        // device for this page ?
        if( deviceCount < deviceStart )
          continue;
        // next row
        displayRow++;
        // 4 per page
        if( displayRow > LCD_ROW5 )
          return;
        // Motor
        if( type == kDeviceTypeMotorSensor ) {
          IQMotors[ index ].velocity = IQMotors[ index ].instance.velocity(velocityUnits::rpm);
          Brain.Screen.printAt( displayRow, 1, "%2d Motor  %+4d rpm", port, (int)IQMotors[ index ].velocity );
        // bumper switch
        if( type == kDeviceTypeBumperSensor ) {
          if( vex::bumper(index).value() )
            Brain.Screen.printAt( displayRow, 1, "%2d Bumper Pressed ", port );
          else
            Brain.Screen.printAt( displayRow, 1, "%2d Bumper Released", port );
        // Touch LED
        if( type == kDeviceTypeLedSensor ) {
          if( vex::touchled(index).value() )
            Brain.Screen.printAt( displayRow, 1, "%2d Led    Pressed ", port );
          else
            Brain.Screen.printAt( displayRow, 1, "%2d Led    Released", port );
        // Color sensor
        if( type == kDeviceTypeRgbSensor ) {
           Brain.Screen.printAt( displayRow, 1, "%2d Color  ", port );
           vex::colorsensor c(index);
          if( c.isNearObject() ) {
              switch( c.colorname12() )
                  default:                         Brain.Screen.printAt( displayRow,10, "No Object "); break;
                  case  colorType::red_violet:     Brain.Screen.printAt( displayRow,10, "RED/VIOLET"); break;
                  case  colorType::red:            Brain.Screen.printAt( displayRow,10, "RED       "); break;
                  case  colorType::red_orange:     Brain.Screen.printAt( displayRow,10, "DRK ORANGE"); break;
                  case  colorType::orange:         Brain.Screen.printAt( displayRow,10, "ORANGE    "); break;
                  case  colorType::yellow_orange:  Brain.Screen.printAt( displayRow,10, "DRK YELLOW"); break;
                  case  colorType::yellow:         Brain.Screen.printAt( displayRow,10, "YELLOW    "); break;
                  case  colorType::yellow_green:   Brain.Screen.printAt( displayRow,10, "LIME GREEN"); break;
                  case  colorType::green:          Brain.Screen.printAt( displayRow,10, "GREEN     "); break;
                  case  colorType::blue_green:     Brain.Screen.printAt( displayRow,10, "BLUE/GREEN"); break;
                  case  colorType::blue:           Brain.Screen.printAt( displayRow,10, "BLUE      "); break;
                  case  colorType::blue_violet:    Brain.Screen.printAt( displayRow,10, "DRK BLUE  "); break;
                  case  colorType::violet:         Brain.Screen.printAt( displayRow,10, "VIOLET    "); break;
            else
                Brain.Screen.printAt( displayRow, 10, "No Object ");
        // Gyro
        if( type == kDeviceTypeGyroSensor ) {
            int angle = vex::gyro(index).angle();
            if( angle < 0 ) angle += 360;
            Brain.Screen.printAt( displayRow, 1, "%2d Gyro    %3d deg", port, angle );
        // Sonar
        if( type == kDeviceTypeSonarSensor ) {
            float dist = vex::sonar(index).distance(distanceUnits::mm);
            Brain.Screen.printAt( displayRow, 1, "%2d Dist   %4d in", port, (int)(dist/25.4) );
/*  Display logo on the home screen when running                               */
void
iqRunDisplayLogo()
    drawBitmap( getLogo() );
/*  Display the little check box with some text next to it                     */
void
iqDrawSelectButtonAndText( int xpos, int row, const char *text )
    int ypos = (row * 11) - 3;
    Brain.Screen.setPenColor( colorType::black );
    Brain.Screen.drawLine( xpos+ 1, ypos,   xpos+ 9, ypos   );
    Brain.Screen.drawLine( xpos+ 1, ypos-8, xpos+ 9, ypos-8 );
    Brain.Screen.drawLine( xpos   , ypos-1, xpos   , ypos-7 );
    Brain.Screen.drawLine( xpos+10, ypos-1, xpos+10, ypos-7 );
    Brain.Screen.drawLine( xpos+ 2, ypos-3, xpos+ 4, ypos-1 );
    Brain.Screen.drawLine( xpos+ 4, ypos-1, xpos+ 8, ypos-5 );
    Brain.Screen.printAt( row, 4, text );
/*  Display information for home screen when running                           */
void
iqRunDisplayHome( bool showExit = false )
    static  long  nPgmStartTime = Brain.Timer.time();
    // display static text
    Brain.Screen.printAt( LCD_ROW1, 1,  "Running" );
    // Calculate robot running time
    long secs  = (Brain.Timer.time() - nPgmStartTime)/1000;
    int  mins  = secs / 60;
    int  hours = mins / 60;
    // display program running time
    Brain.Screen.printAt( LCD_ROW1, 10, "%02d:%02d:%02d", hours, mins % 60, secs % 60 );
    // run/stop/exit select box
    if( showExit )
      iqDrawSelectButtonAndText( 0, LCD_ROW5, "Exit");
    else
    if( robotEnabled )
      iqDrawSelectButtonAndText( 0, LCD_ROW5, "Stop");
    else
      iqDrawSelectButtonAndText( 0, LCD_ROW5, "Run ");
    // Display sonar
    if( robotSonarSensor.installed()) {
        int dist = robotSonarSensor.distance(distanceUnits::mm);
        if( dist > 1000 )
            Brain.Screen.printAt(LCD_ROW5, 9,  "----", dist);
        else
            Brain.Screen.printAt( LCD_ROW5, 9, "%04d", dist);
    // Display gyro
    if( robotGyroSensor.installed()) {
        int heading = robotGyroSensor.angle();
        if( heading < 0 ) heading += 360;
        Brain.Screen.printAt( LCD_ROW5, 14, "%04d", heading);
/*  Action the "run" menu item                                                 */
void
iqMenuRun()
    bool  done = false;
    int select = 0;
    int select_old = 0;
    int selectMax = 2 + (robotTotalDevices-1)/4;
    int pressedTime;
    // Clear the LCD
    // Draw the ROBOTC logo
    iqRunDisplayLogo();
        task::sleep(10);
    // Update LCD and check buttons
    while(!done)
             pressedTime = 0;
             // Down button pushed ?
                if( select++ == selectMax ) select = 0;
            // Up button pushed ?
                if( select-- == 0 ) select = selectMax;
            // Select button pushed ?
            // If select is held then simulate exit
            while( Brain.buttonUp.pressing() || Brain.buttonDown.pressing() || Brain.buttonCheck.pressing()) {
                if( select == 0 && Brain.buttonCheck.pressing()&& pressedTime++ == 120 ) {
                    iqRunDisplayHome( true );
                    done = true;
                task::sleep(10);
            // change of screen ?
            if( select != select_old ) {
                // Clear the LCD display ready for a new status screen
               // Only draw the logo bitmap once when screen 0 is selected
                if( select == 0 )
                    iqRunDisplayLogo();
            select_old = select;
            // Update status based on which status screen has been selected
            switch( select )
                case    0:
                    iqRunDisplayHome();
                    break;
                case    1:
                    iqRunDisplayJoystickStatus();
                    break;
                case    2:
                case    3:
                case    4:
                    iqRunDisplayDeviceStatus( select-2 );
                    break;
                default:
                    break;
        // no need to run often
        task::sleep(50);
    // cleanup
/*  Run a task that handles the main menu                                      */
int
iqMenuTask()
    static  int select = 0;
            bool update = true;
    // Run menu forever
    while( true ) {
        if( update ) {
          // Update main menu, only three items
          iqDisplayLine( LCD_ROW1, select == 0, "Run" );
          iqDisplayLine( LCD_ROW2, select == 1, "Configure" );
          iqDisplayLine( LCD_ROW3, select == 2, "Reset to Default" );
          update = false;
                if( select++ == 2 ) select = 2;
                if( select-- == 0 ) select = 0;
                // reset
                if( select == 2 ) iqResetToDefaults();
                // Enter configure menu
                if( select == 1 ) iqMenuConfiguration();
                // Enter run mode
                if( select == 0 ) {
                    // Gyro sensor installed ?
                        iqCalibrateGyro();
                    // Set everything as enabled
                    robotRunning = true;
                    // Start the control task
                    vex::task t1(iqRunRobotTask, vex::task::taskPriorityHigh);
                    // and display information on the LCD while running...
                    iqMenuRun();
                    // When we return to this point user has indicated program should stop
                    // force task to stop motors and quit
                    robotRunning = false;
                    task::sleep(100);
                    // task should be done
          task::sleep(10);
        // update display
        update = true;
    // Don't hog cpu
    task::sleep(25);
    return(0);
/*  Discover all the motors and sensors connected to the VexIQ                 */
void
iqDiscoverDevices()
    int    type;
    short               index;
    // Clear data
        IQMotors[ index ].installed = false;
        IQMotors[ index ].direction = kNormal;
        IQMotors[ index ].fwdTouch  = NULL;
        IQMotors[ index ].revTouch  = NULL;
    // We have no way to save settings in the simplified code
    // so set to user defaults, full version overrides this
    IQMotors[ (short)PORT1  ].direction = DRIVE_FWD_DEFAULT;
    IQMotors[ (short)PORT6  ].direction = DRIVE_FWD_DEFAULT;
    IQMotors[ (short)PORT4  ].direction = MOTOR_04_DEFAULT;
    IQMotors[ (short)PORT5  ].direction = MOTOR_05_DEFAULT;
    IQMotors[ (short)PORT10 ].direction = MOTOR_10_DEFAULT;
    IQMotors[ (short)PORT11 ].direction = MOTOR_11_DEFAULT;
    robotTotalDevices = 0;
        console::write("device at %2d is %2d\n", index, type );
        // Device found ?
        if( type != kDeviceTypeNoSensor)
          robotTotalDevices++;
        // Motor ?
            // We expect left motors on port 1 and 7
            // We expect right motors on port 6 and 12
            // Aux motors on ports 4,5,10 & 11
            IQMotors[ index ].installed = true;
        // Configure bumper switch to stop motors 4 and 10
            // These seem backwards but match's VEX implementation
            if( index == (short)PORT2 )
                IQMotors[ PORT4  ].revTouch = &Bumper2;
            if( index == (short)PORT3 )
                IQMotors[ PORT4  ].fwdTouch = &Bumper3;
            if( index == (short)PORT8 )
                IQMotors[ PORT10 ].revTouch = &Bumper8;
            if( index == (short)PORT9 )
                IQMotors[ PORT10 ].fwdTouch = &Bumper9;
        // Touch LED on any port used to start stop robot
            robotTouchSensor = vex::touchled(index);
        // Color sensor on any port used to start stop robot
            robotColorSensor = vex::colorsensor(index);
        // Gyro on any port used to reorientate robot
            robotGyroSensor = vex::gyro(index);
        // Sonar on any port used to stop robot
            robotSonarSensor = vex::sonar(index);
int main() {
    // Look for motors and sensors
    iqDiscoverDevices();
    // recover configuration
    iqSettingsRetrieve();
    // start the main menu task
    vex::thread menu( iqMenuTask );
    this_thread::sleep_for(100);
    vex::task::dump();
    while(1) {
        // Allow other tasks to run
        this_thread::sleep_for(10);
here’s the project
iqDefault.iqcpp.zip (11.5 KB)
