When declaring a sylib motor as a global variable, it causes a memory error. Based on my testing, this is because the motor needs to be declared after sylib::initialize(). However, declaring it after sylib::initialize by putting it in main prevents me from using it in files or even other functions in the same cpp file. Is there any way to declare a sylib motor as a global variable without causing a memory error?
I’m not seeing a memory error, do you have an example that demonstrates it ?
Hey, sorry for the late reply. I get a memory error when my code looks like this:
#include "vex.h"
#include "sylib/sylib.hpp"
auto motor = sylib::Motor(17,200, true, motor_speed_controller);
int main() {
sylib::initialize();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
Meanwhile, I don’t get an error when I do this:
#include "vex.h"
int main() {
while (true) {
wait(100, msec);
I appreciate any and all help you can give me, and sorry in advance if I’ve missed something really obvious. Thank you!
When you create a motor in the global scope, it’s being created before sylib::initialize is called, as variables in the global scope are initialized before the main function runs. Here is how you should actually do it:
#include "vex.h"
sylib::Motor motor;
int main() {
while (true) {
wait(100, msec);
Alright, I’ll give this a shot when I can next get access to a brain on Saturday. Thanks for the response.
yea, that’s probably not going to work, I don’t think sylib has a default constructor for the Motor class. The root cause of the memory error is use of vex::mutex in the constructor (and in sylib::initialize() IIRC if that was called as part of a new class in the constructor) outside of a running task. vexos 1.1.3* actually stops the crash (I made a change to handle this issue back in February) but I have no idea if the code then actually works. You have the source for sylib and with suitable changes it could be made to work, I guess that’s the point of using an open source library, understand how it works and change as necessary for your requirements.
*vexos 1.1.3 is not released yet.
Yes, this has been somewhat of a pain for me to deal with. I haven’t found a solution that works in all cases on all platforms. I’m hopeful that with 1.1.3 I can make it work better.
