I want to use more motors in my robot but I don’t have any 5.5W smart motors. Though I have spare 11W smart motors. Is it possible to lower the wattage of some of my 11W smart motors to meet the max wattage cap?
Not that I know of - at inspection, there will be a motor count and use of either 11w or 5.5W in the calculations based on motor type / SKU.
I believe would not be legal to as that’s modifying electrical parts which is illegal as per rule
No. you have to either use 11w motors or 5.5w motors. if you want to programatically limit it for a specific mechanism you can do that programatically but its still gonna count as an 11w motor per the rules
As an alternative to this, you can use things such as
- Motor differential transmissions
Check this out: Vex Differentials Explained - Power take off (PTO)
Check this out: https://www.youtube.com/watch?v=3tkbR7OZv7A
and possibly some more, which I am too lazy to research for. I’ll leave that to you.
5.5W motors are not always the best way to go. I recommend motor sharing when applicable- for example, chaining your intake to your drivetrain so that it will always be running when your drivetrain is, this saves both wattage and code
i don’t know if that’s how i would recommend motor sharing, that would make intake redirects extremely difficult, and honestly seems like a poorly thought-out idea
