Hey guys!
I was wondering if it’s possible if VexCode Pro V5 can open, read, write, and then close files. I’m not very sure if you can and I have been doing some searching around and I haven’t found anything relating to it. I know that PROS can read and write to files on an SD card that is plugged into the robot.
Thanks!
Yes, there are examples here on the forum somewhere.
weilin
November 2, 2020, 4:48am
#3
Here’s a simple example showing how to use the VCS SD card save and load file API. This saves some information into a file called “test.h” on the SD card and then reads it back again.
#include "robot-config.h"
// storage for some information to save
uint8_t myTestData[ 100 ];
uint8_t myReadBuffer[ 1000 ];
int main() {
// set the test data to something detectable
for(int i=0;i<100;i++) {
myTestData* = i * 2;
// write test data to SD Card
int nWritten…
Not sure what you did there, only std::ofstream ofs; needs to be global
I just tried this in VCS and it works.
#include <cstdio>
#include <iostream>
#include <iomanip>
#include <fstream>
std::ofstream ofs;
int main() {
if( Brain.SDcard.isInserted() ) {
// create a file with long filename
ofs.open("a_long_filename_debug.txt", std::ofstream::out);
ofs << "lorem ipsum\r\n";
ofs << "this was a test of a file with long file name\r\n";
o…
