I want to set my motor’s max. rpm to %60. Is there any chance to set the max rpm on code ?
You could make your own function that takes the motor and spin speed which then reduces it to 60% of what you entered.
#include "vex.h"
using namespace vex;
void SpinMax60(motor &Motor, double SpinSpeed){ // Takes in the motor name and spin speed
if(SpinSpeed > 100) // Keeps from values > 100
SpinSpeed = 100;
if(SpinSpeed < -100) // Keeps fro values < -100
SpinSpeed = -100;
SpinSpeed *= 0.6; // Maxes SpinSpeed to 60%
Motor.spin(forward, SpinSpeed, percent); // Spins the motor at reduced speed
int main() {
vexcodeInit();
SpinMax60(Motor1, 100); // Will spin at 60%
