Is there a visual way to create a UI on the cortex screen?
I would like to make a UI for my cortex screen, but I don’t have the time to get all of the values exactly how i want it. Is there a way that I could build it visually, kind of like how you can make in image in MS Paint?
Are you talking about the V5 Brain screen or the Cortex? The Cortex does not have touch screen but the V5 Brain does.
i’m using a v5 brain, I wouldn’t ask if I were using an old cortex
At the risk of being a troll, the V5 brain is NOT the cortex. Using proper terminology prevents confusion.
No there isn’t, but it sounds like a cool project someone should take on.
Is LittlevGL supported by VEXcode text?
Two questions: Is there a way to put this into VEXcode v5 blocks and if so, how do I use it
No, there’s no way to use this with blocks, even with text, it’s pretty advanced stuff.
