I can’t seem to find them anywhere, I’m looking for Spin Up, Science division specifically.
Vexworlds.tv has all the matches from last year. Here’s the HS science division one, for practice matches and quals (elims is a seperate stream).
That link is sending me to this year’s stream.
Whoops, you’re right, I copied the wrong link. This one should work; if not, just go to the vexworlds link, and filter for ended streams. You should be able to find all the ones from last year.
@margarethe Thanks for the help!
Is there any way to watch previous years live streams beyond spin up? I found both the iq and vrc livestreams for last year but I cannot find livestreams beyond that. I am specifically looking for tipping point livestreams. I tried using the BLRS Wiki but the links to past years never load.
I was looking on this, and is it only for Over Under and Spin Up? When I filtered for ended streams, it was blank. Could this something weird with my phone? (Screenshot below)
It appears to be only for Over Under and Spin Up, and it seems that they got rid of Spin Up on the ended streams page. (when I checked yesterday I could view it, but not today) If you go on the BLRS Wiki page that @61539jd linked and select HS then Spin Up, it will take you to the VexTV livestreams last year.
Also, @61539jd, you’re right, it doesn’t seem to work. You might be able to find some videos if you look for tipping point worlds on youtube. (I found a few when I did a quick search) Sorry I couldn’t be of more help.
I know this is solved, but I remember seeing this post a little while ago and I have a related question.
It seems that the firewall in my district is blocking vexworlds.tv. None of my teams are attending Worlds, but I would like to show the stream during class. Is there another place they can be found?
