Is this good Code?
All of our motors work with it.
#include “robot-config.h”
int main()
while(true)
Backleftmotor.spin(vex::directionType::fwd, Controller1.Axis3.value()/2, vex::velocityUnits::pct); //Tank Control : Motor runs at half speed
Backrightmotor.spin(vex::directionType::fwd, Controller1.Axis2.value()/2, vex::velocityUnits::pct); //Tank Control : Motor runs at half speed
if(Controller1.ButtonX.pressing()) // ARM1 motor runs for half speed when B is pressed
Arm1.spin(vex::directionType::fwd, 75, vex::velocityUnits::pct); // 3/4th
else
Arm1.stop(vex::brakeType::hold);
if(Controller1.ButtonB.pressing()) // ARM1 motor runs when Button B is being pressed.
Arm2.spin(vex::directionType::fwd, 75, vex::velocityUnits::pct); // Motor run at 3/4th speed
else
Arm2.stop(vex::brakeType::hold); //holds the arm where it is stopped
if(Controller1.ButtonUp.pressing())//Claw motor should run if Button Up is being pressed
Claw1.spin(vex::directionType::fwd, 75,vex::velocityUnits::pct);//Motor will run at 3/4th speed
else
Claw1.stop(vex::brakeType::hold);//if the button is not being pressed.
if(Controller1.ButtonUp.pressing())//If that button is being pressed
    Claw2.spin(vex::directionType::fwd,75,vex::velocityUnits::pct);//the motor wil run at 3/th speed
else
    Claw2.stop(vex::brakeType::hold);//The motor will stop if it is not pressed.
It would help a lot if you used the code tags when posting.
The big problems I see are the following:
  1. Your code doesn’t match your comments, so I’m not sure it does what you want. Look at ARM1 v. ARM2 and ButtonX v. ButtonB.
  2. You don’t have any ways to run most those motors in other directions. Is that really what you want, to only run each of those arm/claw motors only in a single direction ever?
In addition to the monodirectional arm and claw motor problem identified by @callen, you are also setting both motors in two places. Even if one of them was able to send a reverse signal to those motors, they would fight for control as it would be setting one value then immediately overwriting it with another value. Instead of using two separate
if...else
structures for each motor you should be using a single
if...else if...else
for each. The first
if
checks the up condition, the
else if
checks the down condition, and the
else
case covers the stationary case.
IDK when we tested it the motors worked in both directions.
Are you sure? The comments said this, but I never spotted an actual instance of it. That’s why I said the code doesn’t match the comments.
Really? Arm1, Arm2, Claw1, and Claw2 ran in both directions? With exactly this code? Not Backleftmotor and Backrightmotor, as those should run in both directions.
Yeah they did. I will create the same code with the comments that you all gave me. Thanks so much.
Really??? What button did you press to make ArM1 move backward? What button did you press to move Arm2 backward?
For arm 1 it was buttons y and b
I forgot what it was for arm 2
Then what you were using is not the code you’ve shown us.
int main()
while(true)
else
else
else
else
Looks like you posted the same or very nearly the same code. As I said, what you’ve posted and what you’re describing are not the same code. Look at what you said for ArM1.
Look at what your code says for Arm1 and Arm2.
Arm1 is being controlled by only button X. Meanwhile, button B is actually controlling Arm2.
It makes it very hard for us to help you when you’re posting different code than what you’re describing the robot using.
Ohhhhh I understand now. Thankyou for the help. How would I make the Arm 1 motor run in both directions? Should I do the 75 and -75 thing?
Thankyou so much.
Typically something like this:
if(Controller1.ButtonX.pressing()) {
else if(Controller1.ButtonY.pressing()) {
   Arm1.spin(vex::directionType::rev, 75, vex::velocityUnits::pct);
else {
Ok I understand. Thankyou so much.
So will this code be better? We added the fwd and rev
int main()
while(true)
else {
else
else
This part doesn’t help:
because you have duplicate code to start the next part. This next part is what you want:
I would note that you lost your Arm2 code.
