Hello there,
I was wondering whether WD40 is allowed to be sprayed on robots…
Thanks!
Hello there,
Thanks!
From <R7e>:
If your WD-40 fits the rules, you’d be fine. Basically, you’ll need to make sure you don’t get an aersol WD-40.
Do they make that???
I would be cautious with WD40, as it can congeal after a while, gumming things up more than it helps. I’ve seen sliders get stuck because of it.
We have been using that and it is fine. It helps a lot with double slider on oir A team’s elevator and our scissor’s slider.
We use lithium grease. It seems to work a lot better than WD-40, which only helps for about 10-20 minutes before sticking again. The only annoying part is wiping off the grease if we take apart the robot, but of course, that happens with all lubricants
Quick Tip: Don’t take apart your robots
