Issue with RobotC Debug Stream
I’m having an issue with the debug stream coming up blank while testing my Arduino and Cortex communication.
I’m using jpearman’s code he posted a while ago for Cortex-Arduino Communication.
Here is a photo of the Debug Stream:
Here is the section of code where the debug statements are used:
void
VexDataPrint( vexdata  *v )
    int  i;
    char  str[4];
    for(i=0;i<(VEXDATAOFFSET+v->data.datalen+2);i++)
      sprintf(str, "%02X ", v->buffer*);
      writeDebugStream(str);
    writeDebugStreamLine("");
If anyone could point me in the direction to what the issue might be, that’d be greatly appreciated!*
Did you turn debug on?
If not, uncomment the line of code near the beginning of the file.
//#define DEBUG   1
Remove the “//”
I only sent data to the debug stream if this was defined.
                // comapare checksums
                if( v->data.checksum == c )
                    // Good data
#ifdef  DEBUG
                    VexDataPrint( v );
#endif
                    serialRxDecode( v );
                else
                    serialErrs++;
Otherwise, it’s probably not the code, check the cables etc.
Just uncommented that bit. It worked! Didn’t know how I didn’t see it before. Thanks!
