So I have 3 teams, all having the same issues, all motors that go in reverse glitches, so turning left, and turning right, the motors programmed for reverse glitch while in motion.
Could someone shed some light? I sent 2 feedbacks with my personal email (redacted)
Heres a copy of her code:
# Module: main.py #
# Author: Sheon Catlett #
# Created: Thu Aug 31 20223 #
# Description: VEX Competition Template WIS #
# Library imports
from vex import *
# Brain should be defined by default
brain=Brain()
# Robot Configuration Code
Lfw = Motor(Ports.PORT20, GearSetting.RATIO_18_1,True)
Rfw = Motor(Ports.PORT13, GearSetting.RATIO_18_1,False)
Lbw = Motor(Ports.PORT10, GearSetting.RATIO_18_1,True)
Rbw = Motor(Ports.PORT3, GearSetting.RATIO_18_1,False)
Claw = Motor(Ports.PORT19, GearSetting.RATIO_18_1,True)
FlyW = Motor(Ports.PORT8, GearSetting.RATIO_6_1, True)
SeA = Inertial(Ports.PORT2)
# Motor groups
LSide = MotorGroup(Lfw,Lbw)
RSide = MotorGroup(Rfw,Rbw)
# drivetrain and Controller
Smarty = SmartDrive(Lbw, Rbw, SeA, 300, 320, 320, MM, 1.9)
Dictator = Controller(PRIMARY)
#Functions
def DriveF(direction, distance, speed):
Smarty.set_drive_velocity(speed, PERCENT)
Smarty.drive_for(direction, distance, INCHES)
def LefTurn(direction, angle, speed):
Smarty.turn_to_heading( direction, angle, DEGREES)
Smarty.set_turn_velocity(speed, PERCENT)
def Claw1(direction, angle, speed):
Claw.spin_for(direction, angle, DEGREES)
Claw.set_velocity(speed, PERCENT)
def WheelF(direction, time, speed):
FlyW.spin_for(direction, time, SECONDS)
FlyW.set_velocity(speed, PERCENT)
#Competition Code
def pre_autonomous():
while True:
Smarty.set_stopping(COAST)
SeA.calibrate()
Smarty.set_turn_constant(1.5)
Smarty.set_turn_threshold(1)
def autonomous():
while True:
DriveF(REVERSE, 50, 100)
wait(15000)
def usercontrol():
while True:
Claw.set_velocity(100, PERCENT)
LSide.set_velocity(85, PERCENT)
RSide.set_velocity(85, PERCENT)
FlyW.set_velocity(100, PERCENT)
# controller with joy sticks
Lbw.set_velocity((Dictator.axis3.position() + Dictator.axis1.position()),PERCENT)
Rbw.set_velocity((Dictator.axis3.position() - Dictator.axis1.position()),PERCENT)
Lfw.set_velocity((Dictator.axis3.position() + Dictator.axis1.position()),PERCENT)
Rfw.set_velocity((Dictator.axis3.position() - Dictator.axis1.position()),PERCENT)
Lbw.spin(FORWARD)
Rbw.spin(FORWARD)
Lfw.spin(FORWARD)
Lbw.spin(FORWARD)
#Buttons
if Dictator.buttonR1.pressing():
Claw.spin(REVERSE)
elif Dictator.buttonR2.pressing():
Claw.spin(FORWARD)
else:
Claw.stop(COAST)
if Dictator.buttonUp.pressing():
FlyW.spin(REVERSE)
elif Dictator.buttonDown.pressing():
FlyW.spin(FORWARD)
else:
FlyW.stop(COAST)
comp = Competition(usercontrol, autonomous) #do not touch this
type or paste code here
