Issues with batteries
I have several batteries that have started rapidly flashing the 4th red light on it while the battery is fully charged. When plugged in to a brain it keeps the battery on for a few seconds then it dies. According to this https://kb.vex.com/hc/en-us/articles/360035589652-Interpreting-V5-Battery-Lights-and-Errors it means the battery is critically low but the batteries are fully charged. I have able to get two to connect to battery medic and one has 150 under voltage errors but everything else is fine and then the other one has 4 over volt errors and 145 under volt errors with everything else healthy. The other 6 I can’t keep on long enough to run battery medic. I’ve done some searching but can’t find anything solid on what could be causing this and what to do.
One of my teams had a similar issue a few years ago, and the issue was the battery cord was damaged. When I say battery cord I am referring to the cord that connects the battery and the brain to provide power to the brain. I would try replacing the battery cord and trying again, but if that does not work I have no clue.
