void usercontrol(void){
while(true) {
LeftFront.spin(vex::directionType::fwd, Controller1.Axis3.value(), vex::velocityUnits::pct); //(Axis3+Axis4)/2
RightFront.spin(vex::directionType::fwd, Controller1.Axis2.value(), vex::velocityUnits::pct);//(Axis3-Axis4)/2
vex::task::sleep(20);
//Use these variables to set the speed of the arm and claw.
int armSpeedPCT = 50;
int clawSpeedPCT = 50;
while(true) {
if(Controller1.ButtonL2.pressing()) {
Arm.spin(directionType::fwd, armSpeedPCT, velocityUnits::pct);
else if(Controller1.ButtonL2.pressing()) {
Arm.spin(directionType::rev, armSpeedPCT, velocityUnits::pct);
else {
Arm.stop(brakeType::brake);
if(Controller1.ButtonR2.pressing()) {
Claw.spin(directionType::fwd, clawSpeedPCT, velocityUnits::pct);
else if(Controller1.ButtonR2.pressing()) {
Claw.spin(directionType::rev, clawSpeedPCT, velocityUnits::pct);
else {
Claw.stop(brakeType::brake);
task::sleep(20);
int main() {
while(true) {
if(Controller1.ButtonL1.pressing()) {
Arm1.spin(directionType::fwd, armSpeedPCT, velocityUnits::pct);
else if(Controller1.ButtonL1.pressing()) {
Arm1.spin(directionType::rev, armSpeedPCT, velocityUnits::pct);
else {
Arm1.stop(brakeType::brake);
if(Controller1.ButtonR1.pressing()) {
Claw1.spin(directionType::fwd, clawSpeedPCT, velocityUnits::pct);
else if(Controller1.ButtonR1.pressing()) {
Claw1.spin(directionType::rev, clawSpeedPCT, velocityUnits::pct);
else {
Claw1.stop(brakeType::brake);
task::sleep(20);
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
error main.cpp(4,10)
means there is an error in the file main.cpp
at line 4, column 10.
Is what you posted above the complete contents of main.cpp
? Usually there is some boilerplate (#include
statements, etc.) at the top of the file.
There is usually also some additional content in the “output” tab in VEXcode that gives you some information about what the error is, rather than just where it is in the file.
