Hi, I’m having trouble setting up the auton default constants of the jar template. When I tell it to turn 90 degrees, it does a full 360, and same thing for the swings too. Here’s the code:
#include "vex.h"
void default_constants(){
chassis.set_drive_constants(12, 1.9, 0, 0, 0);
chassis.set_heading_constants(12, .4, 0, 0, 0);
chassis.set_turn_constants(12, 0.4, .0, 0, 0);
chassis.set_swing_constants(12, 0.4, .0, 0, 0);
chassis.set_drive_exit_conditions(1.5, 75, 2000);
chassis.set_turn_exit_conditions(5, 75, 2000);
chassis.set_swing_exit_conditions(1, 75, 2000);
void odom_constants(){
default_constants();
chassis.drive_max_voltage = 8;
chassis.drive_settle_error = 3;
void drive_test(){
// chasstis.drive_distance(6);
chassis.turn_to_angle(90);
// chassis.drive_distance(18);
// chassis.drive_distance(-36);
#include "vex.h"
// Robot Configuration:
// [Name] [Type] [Port(s)]
// LF motor 1
// LM motor 2
// LB motor 3
// RF motor 4
// RM motor 5
// RB motor 6
// Intake motor 21
// ClampL digital_out H
// ClampR digital_out G
// Controller1 controller
// Location inertial 9
using namespace vex;
competition Competition;
/* VEXcode Config */
/* Before you do anything else, start by configuring your motors and */
/* sensors using the V5 port icon in the top right of the screen. Doing */
/* so will update robot-config.cpp and robot-config.h automatically, so */
/* you don't have to. Ensure that your motors are reversed properly. For */
/* the drive, spinning all motors forward should drive the robot forward. */
/* JAR-Template Config */
/* Where all the magic happens. Follow the instructions below to input */
/* all the physical constants and values for your robot. You should */
/* already have configured your robot manually with the sidebar configurer. */
Drive chassis(
//Specify your drive setup below. There are seven options:
//ZERO_TRACKER_NO_ODOM, ZERO_TRACKER_ODOM, TANK_ONE_ENCODER, TANK_ONE_ROTATION, TANK_TWO_ENCODER, TANK_TWO_ROTATION, HOLONOMIC_TWO_ENCODER, and HOLONOMIC_TWO_ROTATION
//For example, if you are not using odometry, put ZERO_TRACKER_NO_ODOM below:
ZERO_TRACKER_ODOM,
//Add the names of your Drive motors into the motor groups below, separated by commas, i.e. motor_group(Motor1,Motor2,Motor3).
//You will input whatever motor names you chose when you configured your robot using the sidebar configurer, they don't have to be "Motor1" and "Motor2".
//Left Motors:
motor_group(LF,LM,LB),
//Right Motors:
motor_group(RF,RM,RB),
//Specify the PORT NUMBER of your inertial sensor, in PORT format (i.e. "PORT1", not simply "1"):
PORT9,
//Input your wheel diameter. (4" omnis are actually closer to 4.125"):
3.25,
//External ratio, must be in decimal, in the format of input teeth/output teeth.
//If your motor has an 84-tooth gear and your wheel has a 60-tooth gear, this value will be 1.4.
//If the motor drives the wheel directly, this value is 1:
0.6,
//Gyro scale, this is what your gyro reads when you spin the robot 360 degrees.
//For most cases 360 will do fine here, but this scale factor can be very helpful when precision is necessary.
360,
/* PAUSE! */
/* The rest of the drive constructor is for robots using POSITION TRACKING. */
/* If you are not using position tracking, leave the rest of the values as */
/* they are. */
//If you are using ZERO_TRACKER_ODOM, you ONLY need to adjust the FORWARD TRACKER CENTER DISTANCE.
//FOR HOLONOMIC DRIVES ONLY: Input your drive motors by position. This is only necessary for holonomic drives, otherwise this section can be left alone.
//LF: //RF:
PORT1, -PORT2,
//LB: //RB:
PORT3, -PORT4,
//If you are using position tracking, this is the Forward Tracker port (the tracker which runs parallel to the direction of the chassis).
//If this is a rotation sensor, enter it in "PORT1" format, inputting the port below.
//If this is an encoder, enter the port as an integer. Triport A will be a "1", Triport B will be a "2", etc.
PORT9,
//Input the Forward Tracker diameter (reverse it to make the direction switch):
2.75,
//Input Forward Tracker center distance (a positive distance corresponds to a tracker on the right side of the robot, negative is left.)
//For a zero tracker tank drive with odom, put the positive distance from the center of the robot to the right side of the drive.
//This distance is in inches:
5.5,
//Input the Sideways Tracker Port, following the same steps as the Forward Tracker Port:
1,
//Sideways tracker diameter (reverse to make the direction switch):
-2.75,
//Sideways tracker center distance (positive distance is behind the center of the robot, negative is in front):
5.5
int current_auton_selection = 0;
bool auto_started = false;
void pre_auton(void) {
vexcodeInit();
while(auto_started == false){ //Changing the names below will only change their names on the
Brain.Screen.clearScreen(); //brain screen for auton selection.
switch(current_auton_selection){ //Tap the brain screen to cycle through autons.
case 0:
Brain.Screen.printAt(50, 50, "Drive Test");
break;
case 1:
break;
case 2:
Brain.Screen.printAt(50, 50, "Turn Test");
break;
case 3:
Brain.Screen.printAt(50, 50, "Swing Test");
break;
case 4:
Brain.Screen.printAt(50, 50, "Full Test");
break;
case 5:
Brain.Screen.printAt(50, 50, "Odom Test");
break;
case 6:
Brain.Screen.printAt(50, 50, "Tank Odom Test");
break;
case 7:
Brain.Screen.printAt(50, 50, "Holonomic Odom Test");
break;
if(Brain.Screen.pressing()){
while(Brain.Screen.pressing()) {}
current_auton_selection ++;
} else if (current_auton_selection == 8){
task::sleep(10);
void autonomous(void) {
auto_started = true;
case 0:
drive_test(); //This is the default auton, if you don't select from the brain.
break; //Change these to be your own auton functions in order to use the auton selector.
case 1: //Tap the screen to cycle through autons.
drive_test();
break;
case 2:
turn_test();
break;
case 3:
swing_test();
break;
case 4:
full_test();
break;
case 5:
odom_test();
break;
case 6:
tank_odom_test();
break;
case 7:
holonomic_odom_test();
break;
edit: code tags added by mods, please remember to use them.
