I have successfully paired the cortex and joystick. But a minute or so after the robot is running, a red light pops up on either the joystick or the cortex and the machine stops. Batteries are good in both units. Any ideas?
Does the control lights and the cortex lights all flash red then stop? If so you may need to try configuring your controller. You can also try manually updating the firmware on both the controller and cortex then redownload the program.
What do you mean by configuring the controller?
I will definitely check the firmware issue though!
Thank you!
Welcome!
