Joystick spring broke
Over the last competition, my team broke the right-side joystick. Basically, it won’t “spring back” to the centered position. This is the second one (we had one like this last year, but it was brand new). I suspect that the controller is more than a year old. I plan on calling Vex to see what, if any, advice they have for fixing/replacing it. If it is out of warranty, any thoughts on how to attempt to repair it?
Also, does this happen to other teams? Or are we just lucky?
Try pushing the joystick in, you might have just pulled it up which causes it to have more friction
I would contact vex and see if you can send it to be repaired. I think the problem originated because you were brutal of the joystick. Whoever drives it is probably applying too much force with their right hand without realizing it. A temporary solution to this would be to code in a large dead zone on the joystick and lean to manually reset it.
