What do you use Jump Clips for and what do they do(do they just light up?) ?
I tried to look at other forums and couldn’t find out.
I could be wrong when I say this but I found this online.
In competitive robotics, jumper clips are for the most part used to select an autonomous routine before a match. Set up your autonomous code to say something like, “If there’s a jumper in Digital3, then run autonomous pattern xxx”; “Otherwise, if there’s a jumper in Digital 4, then run autonomous pattern yyy.” In this regard, jumper clips serve the same function as an LCD screen, but don’t cost $50. In fact, you probably already own some clips, as they come included when you buy a cortex. Source-VEX Sensors: Jumper Clips & LED Indicators • Renegade Robotics.
However, Jumpers were deprecated in V5, and can no longer be queried with VexCode.
So I can’t use it anymore?
If I can, what should I select for the menu inside the 3 wire port.
I believe you can use it as a bump switch if I’m not mistaken
sure they can, just configure the 3wire port as a digital input or switch and read the value.
